[mapguide-users] Need Highlighting Sample
Matt Wilson
mwilson at mswis.com
Thu Oct 1 20:33:34 EDT 2009
Hello Jackie,
I do have some experience with RealDWG, are you saying that I can convert DWG to SDF using RealDWG?
Thanks,
Matt
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, October 01, 2009 5:12 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Need Highlighting Sample
Autodesk replaced DETE with RealDWG in Studio 2009 thus explaining the
different behaviour.
- Jackie
Andy Morsell wrote:
> Quote Gordon: " Although you can load DWG files, you cannot get OBJECT
> DATA,
> BLOCK ATTRIBUTES or LINK TEMPLATES."
> You used to be able to with Autodesk MapGuide Studio 2008 and below by
> defining feature classes in Map. As part of the feature class, you could
> assign the object data or data link attributes and then Studio would let
> you
> import the entire feature class. But, Autodesk did away with the
> capability
> in Studio 2009 for whatever reason so now people are stuck doing this
> outside of MapGuide.
> I do the same thing as your last description: export from Map to SDF with
> the object data or link template data then load on to the MapGuide server
> and connect to the folder via an alias. For performance reasons, I do
> this
> in lieu of exporting with only the key and using a database join in
> MapGuide.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> 47° 46' N 116° 49' W
> www.SpatialGIS.com
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
> Sent: Thursday, October 01, 2009 12:12 PM
> Subject: Re: [mapguide-users] Need Highlighting Sample
> Hi Matt,
> the one item I want to mention here is the Load Procedure for DWG.
> Although you can load DWG files, you cannot get OBJECT DATA, BLOCK
> This is a huge chasm between DWG and FDO and its has been a hole in
> AutoCAD
> Map to MapGuide since the early days of FDO.
> The only way accross is an EXPORT to SDF (or other FDO data store) so
> MapGuide can see it.
> I would recommend using FME from Safe software to facilite the DWG with
> OBJECT DATA to SDF.
> You can't do it directly with MapGuide OS, MapGuide Enterprise, or Map 3D
> (or any other Autodesk product) directly - only via EXPORT to FDO.
> Also, if you are using Map 3D to view FDO data stores (i.e. MySQL, SDF,
> Oracle, etc) you cannot quickly convert the data into linework with Object
> Data.
> Best way to use MapGuide - export your DWG into SDF (keeping the Object
> Data) and then load the SDF using a Load Procedure or Alias a folder on
> the
> server.
> regards
> gordon
> ps. Once you have data that has a Key that you really want (not Handle -
> blech!), you can find a lot of examples on
> http://data.mapguide.com/mapguide/devguide/index.php check out the
> working
> with feature data for samples with the selection ...
> mwilson wrote:
>> Hello,
>> I am using MapGuide Enterprise 2010 and am in need of a simplified
>> example for how to highlight items on a map. I used MapGuide Studio
>> 2010 to import data from a dwg drawing. The drawing contains a 2d
>> rendering of a building floor. I am trying to figure out how to
>> hilight various rooms (or polylines) within the floor. Can
>> someone please point me in the direction of an example that might show me
>> how to highlight polylines within a map. Also is it possible to
>> highlight ojbects based on their entity handle or is this info lost when
>> importing from dwg.
>> Fyi, I am using the AJAX viewer and coding in .net.
>> Many thanks in advance,
>> Matt
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/Need-Highlighting-Sample-tp3751164p3751366.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/Need-Highlighting-Sample-tp3751164p3752881.html
