[mapguide-users] Edit polygon
ama.stan
samalia at blacklight.ro
Fri Oct 2 08:06:21 EDT 2009
Hy. I saw what you wrote here and i want to ask for some help , i would like
to draw points, line, polygons using fusion in mapguide.please help me. i
try to draw with the exemples in the phpsample but i can't succes. if you
have some code please help me.
Thank you so much.
A H wrote:
> yeah, as stated, we already have drawing functionality, as well as saving
> and loading the areas. the problem now is editing the polygons.
> Dragan Podvezanec wrote:
>> Hi.
>> Imho,
>> It's not too hard to add Drawing functionality, since API supports it.
>> Adding point,line and polygon to map and storing it into spatial database
>> is easy through DigitizePoint, DigitizePolygon and DigitizeLine. If you
>> wish, I can send you sample code.
>> But, editing is something totally different. You would have to add
>> functions like snapping, checking the topology, and moving polygons.
View this message in context: http://n2.nabble.com/Edit-polygon-tp1818671p3754961.html
