[mapguide-users] Fusion Error (Object Doesn't Supported)
Paul Spencer pagameba at gmail.com
Fri Oct 2 08:29:31 EDT 2009
On 2009-10-02, at 4:56 AM, ary_s wrote:
> Jackie Ng wrote:
>> Are you using the compressed or non-compressed version? Do you get
>> the
>> same result when you switch?
>> - Jackie
>> ary_s wrote:
>>> Hii group,
>>> I'm having with fusion 1.0/2.0 with MGOS 2.1. FusionSF keep on
>>> saying
>>> object doesn't supported when i tried to view it on my browser. I
>>> would
>>> like to know if anybody manage to use fusion with MGOS 2.1? What
>>> version
>>> is suitable for it?
>>> thanks,
> I have switched between compressed and not, both gave me the same
> error.
> thanks
fusion from svn trunk does work with MGOS 2.1 (I think it was bundled
with the last installer), I would imagine the current 2.0 beta version
should work as well.
We will need some more details, specifically which browser you are
using.  The wording of the error looks like you are using Internet
Explorer, we'll need to know which version.  Also, it would be
extremely helpful if you could install a debugger (unless you are
using IE 8, which comes with one) for IE and debug it in the code so
we know where it is failing (use the uncompressed version for this).
Also, it is very useful to know if this happens in other browsers
(firefox is the best to check in)
Cheers
Paul
