[mapguide-users] Fusion Error (Object Doesn't Supported)
ary_s ary.sucaya at yahoo.com
Mon Oct 5 04:44:35 EDT 2009
Paul Spencer wrote:
> On 2009-10-02, at 4:56 AM, ary_s wrote:
>> Jackie Ng wrote:
>>> Are you using the compressed or non-compressed version? Do you get
>>> the
>>> same result when you switch?
>>> - Jackie
>>> ary_s wrote:
>>>> Hii group,
>>>> I'm having with fusion 1.0/2.0 with MGOS 2.1. FusionSF keep on
>>>> saying
>>>> object doesn't supported when i tried to view it on my browser. I
>>>> would
>>>> like to know if anybody manage to use fusion with MGOS 2.1? What
>>>> version
>>>> is suitable for it?
>>>> thanks,
>> I have switched between compressed and not, both gave me the same
>> error.
>> thanks
> fusion from svn trunk does work with MGOS 2.1 (I think it was bundled
> with the last installer), I would imagine the current 2.0 beta version
> should work as well.
> We will need some more details, specifically which browser you are
> using.  The wording of the error looks like you are using Internet
> Explorer, we'll need to know which version.  Also, it would be
> extremely helpful if you could install a debugger (unless you are
> using IE 8, which comes with one) for IE and debug it in the code so
> we know where it is failing (use the uncompressed version for this).
> Also, it is very useful to know if this happens in other browsers
> (firefox is the best to check in)
> Cheers
> Paul
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Thank for reply,
Here is an error in FusionSF-compressed:
var
E=B.getHeader("Content-type")}try{(this.options["on"+C]||OpenLayers.Ajax.emptyFunction)(B);OpenLayers.Ajax.Responders.dispatch("on"+C,this,B)}.
The error gone when i remove widgetset definition from application
definition...
I'm using IE 7
View this message in context: http://n2.nabble.com/Fusion-Error-Object-Doesn-t-Supported-tp3753421p3767628.html
