[mapguide-users] JSP and PHP and fusion
Paul Spencer pagameba at gmail.com
Sun Oct 4 18:28:17 EDT 2009
I'm not sure, hopefully someone else will jump in with an answer
here.  I've never installed anything except PHP.  If I recall
correctly, PHP is installed when you include the mapguide admin tool
since it is written in PHP, perhaps you don't need to do anything?
Cheers
Paul
On 2009-10-04, at 5:57 PM, oshan wrote:
> Hey guys
> Thanks for all your replies!
> Spencer How would I install both PHP and JSP? If I rmbr correctly in
> the
> installation process I can only choose JSP or PHP! And I choose JSP.
> Does
> this mean I will need to go back and install the PHP web API as well
> for
> fusion to work? or will I have to do I reinstall and this time only
> install
> PHP API?
> Thanks
> Paul Spencer wrote:
>> Fusion is still unfortunately buggy in some specific areas, your
>> mileage will vary depending on how you use it (we use it extensively
>> without problems - or at least we fix the problems as we run into
>> them).  Fusion is designed to support alternate back ends (jsp,
>> php, .net) but only the PHP version exists at this time so you do
>> have
>> to have both PHP and JSP versions of mapguide web tier installed -
>> there have been reports of using fusion/php and developing task panes
>> in .NET and perhaps JSP successfully.
>> Cheers
>> Paul
>> On 2009-09-24, at 3:33 AM, oshan wrote:
>>> Hey Guys
>>> So I'm just trying to get started with mapguide. I want to know if
>>> there is
>>> any Documentation specific to using the JSP API. The developers
>>> guide seams
>>> focus on PHP.
>>> Also what do you guys think is better to use PHP or JSP?
>>> The reason why I am leaning towards JSP is because it is essentially
>>> Java
>>> programming and I am familiar with Java (altho I have never used
>>> JSP)
>>> where
>>> as I have only slight knowledge with PHP and I also have the
>>> perception that
>>> since its Java with the whole OO stuff, it'll prolly be easy to
>>> program in!?
>>> Since I couldn't find any JSP documentation I looked at the sample
>>> JSP ajax
>>> viewer code and it looks a bit scary: there is a whole lot of code!
>>> I would
>>> like to see more of a step by step approach with JSP.
>>> Also I looked into this fusion thing but it seams a bit buggy. I
>>> don't know
>>> if any of you have experienced that. Like I would specify some
>>> widgets but
>>> they would never show up. I heard that fusion use PHP for it server
>>> stuff.
>>> Does this mean I have to configure mapguide to use PHP instead of
>>> JSP. when
>>> I install it I set it up to use JSP!
>>> thanks
>>> View this message in context:
>>> http://n2.nabble.com/JSP-and-PHP-and-fusion-tp3704607p3704607.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://n2.nabble.com/JSP-and-PHP-and-fusion-tp3704607p3765568.html
