[mapguide-users] JSP and PHP and fusion
oshan icycool at inbox.com
Sun Oct 4 17:57:12 EDT 2009
Hey guys
Thanks for all your replies!
Spencer How would I install both PHP and JSP? If I rmbr correctly in the
installation process I can only choose JSP or PHP! And I choose JSP. Does
this mean I will need to go back and install the PHP web API as well for
fusion to work? or will I have to do I reinstall and this time only install
PHP API?
Thanks
Paul Spencer wrote:
> Fusion is still unfortunately buggy in some specific areas, your
> mileage will vary depending on how you use it (we use it extensively
> without problems - or at least we fix the problems as we run into
> them).  Fusion is designed to support alternate back ends (jsp,
> php, .net) but only the PHP version exists at this time so you do have
> to have both PHP and JSP versions of mapguide web tier installed -
> there have been reports of using fusion/php and developing task panes
> in .NET and perhaps JSP successfully.
> Cheers
> Paul
> On 2009-09-24, at 3:33 AM, oshan wrote:
>> Hey Guys
>> So I'm just trying to get started with mapguide. I want to know if
>> there is
>> any Documentation specific to using the JSP API. The developers
>> guide seams
>> focus on PHP.
>> Also what do you guys think is better to use PHP or JSP?
>> The reason why I am leaning towards JSP is because it is essentially
>> Java
>> programming and I am familiar with Java (altho I have never used JSP)
>> where
>> as I have only slight knowledge with PHP and I also have the
>> perception that
>> since its Java with the whole OO stuff, it'll prolly be easy to
>> program in!?
>> Since I couldn't find any JSP documentation I looked at the sample
>> JSP ajax
>> viewer code and it looks a bit scary: there is a whole lot of code!
>> I would
>> like to see more of a step by step approach with JSP.
>> Also I looked into this fusion thing but it seams a bit buggy. I
>> don't know
>> if any of you have experienced that. Like I would specify some
>> widgets but
>> they would never show up. I heard that fusion use PHP for it server
>> stuff.
>> Does this mean I have to configure mapguide to use PHP instead of
>> JSP. when
>> I install it I set it up to use JSP!
>> thanks
>> View this message in context:
>> http://n2.nabble.com/JSP-and-PHP-and-fusion-tp3704607p3704607.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/JSP-and-PHP-and-fusion-tp3704607p3765568.html
