[mapguide-users] shp2pgsql
Akram
akram at gsg-eg.com
Sat Oct 3 10:06:12 EDT 2009
1- open command window from start>run>cmd , then by command cd open the
fillowing path C:\Program Files\PostgreSQL\8.3\bin and make sure that in
this path executable file called shp2pgsql.exe
http://n2.nabble.com/file/n3760302/untitled.bmp
2-Now You can load shapefile into PostGIS
Shp2pgsql.exe –I –D d:\shapes\stations.shp stations | psql postgis postgres
• Command Name : Shp2pgsql.exe
• Command Options : -I –D (that is a captial ‘i’)
This means create a
spatial index
Load using dump format (faster)
• The path to the shape file
• The table name to load the file into.
• The pipe (|): send the output of shp2pgsql to psql
• Psql : the command line sql client for PostgreSQL
• Postgis: the database you want to load the shape file into.
• Postgres: the username to connect to the database with.
http://gsg-eg.com
http://n2.nabble.com/file/u111068/head2.jpg
GeoService
View this message in context: http://n2.nabble.com/shp2pgsql-tp1818379p3760302.html
