[mapguide-users] wms from other providers
Jo Cook
j.cook at oxfordarch.co.uk
Tue Oct 6 13:07:19 EDT 2009
Hi Jason,
For this data I need a range of options (some of the files are behind a
firewall so direct connections are problematic). I definitely seem to need
to add the width and height parameters to the config.xml file for the wms
FeatureSource, so it would be interesting to see if anyone else has this
issue, in which case I think the documentation needs updating.
I have dealt with the bounding box issue by removing any references to other
EPSG codes- when it's all in EPSG 27700 it seems happy enough.
Actually the biggest thing that I've learnt is that dealing with mapinfo
data is problematic, especially when it's someone else's...
Thanks
Jo
Jason Birch wrote:
> Jo,
> Is it an option to use MapGuide as the WMS provider, or to connect to the
> MapInfo files directly? These are both not solutions, but maybe worth
> trying if the files are in your control. I'm thinking that the OGR
> provider
> should allow you to connect to the MapInfo files.
> Jason
> 2009/10/5 Jo Cook <j.cook at oxfordarch.co.uk>
View this message in context: http://n2.nabble.com/wms-from-other-providers-tp3755455p3776398.html
