[mapguide-users] draw a rectangle in the map and drag it (with AJAX
viewer)
Peter Scigalla
scigalla at battefeld.com
Wed Oct 7 05:15:04 EDT 2009
Hello,
what I want to do:
Draw a rectangle (a print frame) in the map and drag it to the desired
position with the mouse. How can I do it?
What I have done:
1. Digitize a point in the map
2. Calculate the rectangle based on this point-coordinates
3. Save the rectangle in the MySQL database and refresh the map to show it.
It works fine. My problem is the replacing of the rectangle. First I
have to delete it and then digitze a new point. It works, but it is only
a workaround.
Much more convenient would be a behaviour like e.g. in this
(openlayers-)example:
http://www.openlayers.org/dev/examples/modify-feature.html
How to do something like this in MGOS?
Thanks in advance.
Regards - Peter
MGOS 2.0.2
Apache, PHP, MySQL
AJAX viewer
