[mapguide-users] draw a rectangle in the map and drag it (with
AJAX viewer)
psciga
scigalla at battefeld.com
Thu Oct 15 04:20:24 EDT 2009
Sorry for reposting, but is there not any idea?
Best regards - Peter
psciga wrote:
> Hello,
> what I want to do:
> Draw a rectangle (a print frame) in the map and drag it to the desired
> position with the mouse. How can I do it?
> What I have done:
> 1. Digitize a point in the map
> 2. Calculate the rectangle based on this point-coordinates
> 3. Save the rectangle in the MySQL database and refresh the map to show
> it.
> It works fine. My problem is the replacing of the rectangle. First I
> have to delete it and then digitze a new point. It works, but it is only
> a workaround.
> Much more convenient would be a behaviour like e.g. in this
> (openlayers-)example:
> http://www.openlayers.org/dev/examples/modify-feature.html
> How to do something like this in MGOS?
> Thanks in advance.
> Regards - Peter
> MGOS 2.0.2
> Apache, PHP, MySQL
> AJAX viewer
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/draw-a-rectangle-in-the-map-and-drag-it-with-AJAX-viewer-tp3780621p3827927.html
