[mapguide-users] Virtual Earth and Firefox with FUSION?
Paul Spencer
pagameba at gmail.com
Thu Oct 8 20:29:13 EDT 2009
When I run this in firefox 3.5.2 on OS X it fails to load and I see a
javascript error in firebug
this.scroller.getStyle('left') has no properties
If I turn on 'Break on all errors' in firebug and reload, I get a
number of exceptions that can be safely continued from (they are in
try/catch blocks but firefox stops on them anyway) and, strangely,
everything eventually loads and works.
Very strange. This behaviour is normally the opposite, firefox works
and the other browsers don't.
I don't really know what to think about this. Not sure if it is due
to being in an iframe, a timing issue loading the ms maps api or
something else
Can you try with firebug and see if you get the same thing (with break
on all errors on)
Cheers
Paul
On 2009-10-08, at 8:13 PM, GordonL wrote:
> No Kori, I never did find a solution. I am running it at
> http://www.mapguide.ca/sydney/ but I can't get it work in FireFox
> (just
> Safari and Internet Explorer)
> gordon
> Kori Maleski wrote:
>> Hi Gordon,
>> Did you find a work around or determine what the issue was? I am
>> using
>> the
>> SVN trunk version and hit the same snag.
>> Cheers,
>> Kori Maleski
>> On Tue, Aug 11, 2009 at 11:47 AM, GordonL
>> <gordon.luckett at arrowgeomatics.com
>>> wrote:
>>> Hi All, I have a strange issue. For some reason the Virtual Earth
>>> OpenLayers
>>> overlay only seems to work with Internet Explorer (Windows) and
>>> Safari
>>> (Windows and MacBook Pro), but no Firefox (any OS).
>>> I am not sure what the issue is, but I checked out the openlayers
>>> demo
>>> (http://openlayers.org/dev/examples/spherical-mercator.html) and the
>>> OpenLayers seemed to handle Virtual Earth and Firefox nicely..so I
>>> think
>>> it
>>> might be how FUSION is implemented the OpenLayers (I am using the
>>> Full
>>> openlayers.js file too).
>>> And:
>>> <script
>>> src='http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.1
>>> '></script>
>>> Oh and the code to add the VE Layer in the INDEX.htm
>>> var mapWidget = Fusion.getWidgetById('Map');
>>> var map = mapWidget.oMapOL;
>>> mapWidget.fractionalZoom = false;
>>> map.setOptions({fractionalZoom: false, numZoomLevels: 30});
>>> //Create Virtual Earth - Live Maps example
>>> velayer = new OpenLayers.Layer.VirtualEarth('VE', {
>>> 'sphericalMercator': true,
>>> 'type': VEMapStyle.Road
>>> map.addLayer(velayer);
>>> var mgLayers = map.getLayersByClass('OpenLayers.Layer.MapGuide');
>>> if(mgLayers.length != 0)
>>> var mgLayer = mgLayers[0];
>>> if(mgLayer.isBaseLayer)
>>> map.setBaseLayer(velayer);
>>> mgLayer.setIsBaseLayer(false);
>>> mgLayer.setVisibility(true);
>>> See what I mean by using Firefox at:
>>> http://mapguide.ca/sydney/ http://mapguide.ca/sydney/
>>> regards
>>> gordon
>>> View this message in context:
>>> http://n2.nabble.com/Virtual-Earth-and-Firefox-with-FUSION--tp3426002p3426002.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://n2.nabble.com/Virtual-Earth-and-Firefox-with-FUSION-tp3426002p3791581.html
