[mapguide-users] Virtual Earth and Firefox with FUSION?
Kori Maleski
kori.maleski at gmail.com
Thu Oct 8 20:34:29 EDT 2009
Stepping through right now.
I will follow up tomorrow.
Thanks Paul,
Cheers,
Kori Maleski
On Thu, Oct 8, 2009 at 5:29 PM, Paul Spencer <pagameba at gmail.com> wrote:
> When I run this in firefox 3.5.2 on OS X it fails to load and I see a
> javascript error in firebug
> this.scroller.getStyle('left') has no properties
> If I turn on 'Break on all errors' in firebug and reload, I get a number of
> exceptions that can be safely continued from (they are in try/catch blocks
> but firefox stops on them anyway) and, strangely, everything eventually
> loads and works.
> Very strange. This behaviour is normally the opposite, firefox works and
> the other browsers don't.
> I don't really know what to think about this. Not sure if it is due to
> being in an iframe, a timing issue loading the ms maps api or something else
> Can you try with firebug and see if you get the same thing (with break on
> all errors on)
> Cheers
> Paul
> On 2009-10-08, at 8:13 PM, GordonL wrote:
>> No Kori, I never did find a solution. I am running it at
>> http://www.mapguide.ca/sydney/ but I can't get it work in FireFox (just
>> Safari and Internet Explorer)
>> gordon
>> Kori Maleski wrote:
>>> Hi Gordon,
>>> Did you find a work around or determine what the issue was? I am using
>>> the
>>> SVN trunk version and hit the same snag.
>>> Cheers,
>>> Kori Maleski
>>> On Tue, Aug 11, 2009 at 11:47 AM, GordonL
>>> <gordon.luckett at arrowgeomatics.com
>>>> wrote:
>>>> Hi All, I have a strange issue. For some reason the Virtual Earth
>>>> OpenLayers
>>>> overlay only seems to work with Internet Explorer (Windows) and Safari
>>>> (Windows and MacBook Pro), but no Firefox (any OS).
>>>> I am not sure what the issue is, but I checked out the openlayers demo
>>>> (http://openlayers.org/dev/examples/spherical-mercator.html) and the
>>>> OpenLayers seemed to handle Virtual Earth and Firefox nicely..so I think
>>>> it
>>>> might be how FUSION is implemented the OpenLayers (I am using the Full
>>>> openlayers.js file too).
>>>> And:
>>>> <script
>>>> src='http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.1
>>>> '></script>
>>>> Oh and the code to add the VE Layer in the INDEX.htm
>>>> var mapWidget = Fusion.getWidgetById('Map');
>>>> var map = mapWidget.oMapOL;
>>>> mapWidget.fractionalZoom = false;
>>>> map.setOptions({fractionalZoom: false, numZoomLevels: 30});
>>>> //Create Virtual Earth - Live Maps example
>>>> velayer = new OpenLayers.Layer.VirtualEarth('VE', {
>>>> 'sphericalMercator': true,
>>>> 'type': VEMapStyle.Road
>>>> map.addLayer(velayer);
>>>> var mgLayers = map.getLayersByClass('OpenLayers.Layer.MapGuide');
>>>> if(mgLayers.length != 0)
>>>> var mgLayer = mgLayers[0];
>>>> if(mgLayer.isBaseLayer)
>>>> map.setBaseLayer(velayer);
>>>> mgLayer.setIsBaseLayer(false);
>>>> mgLayer.setVisibility(true);
>>>> See what I mean by using Firefox at:
>>>> http://mapguide.ca/sydney/ http://mapguide.ca/sydney/
>>>> regards
>>>> gordon
>>>> View this message in context:
>>>> http://n2.nabble.com/Virtual-Earth-and-Firefox-with-FUSION--tp3426002p3426002.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://n2.nabble.com/Virtual-Earth-and-Firefox-with-FUSION-tp3426002p3791581.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091008/b25c3744/attachment.html
