[mapguide-users] Virtual Earth and Firefox with FUSION?
GordonL gordon.luckett at arrowgeomatics.com
Thu Oct 8 21:49:59 EDT 2009
Thanks Paul,
I don't think its an iFrame issue, I checked the site without the iFrame
(http://mapguide.ca/mapguide2010/fusion/templates/mapguide/liveaqua/index.html?APPLICATIONDEFINITION=Library://Sydney/6_LAYOUTS/SYDNEY_LAYOUT.ApplicationDefinition)
and same error (left)
gordon
Paul Spencer wrote:
> When I run this in firefox 3.5.2 on OS X it fails to load and I see a
> javascript error in firebug
> this.scroller.getStyle('left') has no properties
> If I turn on 'Break on all errors' in firebug and reload, I get a
> number of exceptions that can be safely continued from (they are in
> try/catch blocks but firefox stops on them anyway) and, strangely,
> everything eventually loads and works.
> Very strange.  This behaviour is normally the opposite, firefox works
> and the other browsers don't.
> I don't really know what to think about this.  Not sure if it is due
> to being in an iframe, a timing issue loading the ms maps api or
> something else
> Can you try with firebug and see if you get the same thing (with break
> on all errors on)
> Cheers
> Paul
> On 2009-10-08, at 8:13 PM, GordonL wrote:
>> No Kori, I never did find a solution.  I am running it at
>> http://www.mapguide.ca/sydney/ but I can't get it work in FireFox
>> (just
>> Safari and Internet Explorer)
>> gordon
>> Kori Maleski wrote:
>>> Hi Gordon,
>>> Did you find a work around or determine what the issue was?  I am
>>> using
>>> the
>>> SVN trunk version and hit the same snag.
>>> Cheers,
>>> Kori Maleski
>>> On Tue, Aug 11, 2009 at 11:47 AM, GordonL
>>> <gordon.luckett at arrowgeomatics.com
>>>> wrote:
>>>> Hi All, I have a strange issue.  For some reason the Virtual Earth
>>>> OpenLayers
>>>> overlay only seems to work with Internet Explorer (Windows) and
>>>> Safari
>>>> (Windows and MacBook Pro), but no Firefox (any OS).
>>>> I am not sure what the issue is, but I checked out the openlayers
>>>> demo
>>>> (http://openlayers.org/dev/examples/spherical-mercator.html) and the
>>>> OpenLayers seemed to handle Virtual Earth and Firefox nicely..so I
>>>> think
>>>> it
>>>> might be how FUSION is implemented the OpenLayers (I am using the
>>>> Full
>>>> openlayers.js file too).
>>>> And:
>>>> <script
>>>> src='http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.1
>>>> '></script>
>>>> Oh and the code to add the VE Layer in the INDEX.htm
>>>>   var mapWidget = Fusion.getWidgetById('Map');
>>>>   var map = mapWidget.oMapOL;
>>>>   mapWidget.fractionalZoom = false;
>>>>   map.setOptions({fractionalZoom: false, numZoomLevels: 30});
>>>> //Create Virtual Earth - Live Maps example
>>>>   velayer = new OpenLayers.Layer.VirtualEarth('VE', {
>>>>               'sphericalMercator': true,
>>>>               'type': VEMapStyle.Road
>>>>   map.addLayer(velayer);
>>>>   var mgLayers = map.getLayersByClass('OpenLayers.Layer.MapGuide');
>>>>   if(mgLayers.length != 0)
>>>>       var mgLayer = mgLayers[0];
>>>>       if(mgLayer.isBaseLayer)
>>>>           map.setBaseLayer(velayer);
>>>>           mgLayer.setIsBaseLayer(false);
>>>>           mgLayer.setVisibility(true);
>>>> See what I mean by using Firefox at:
>>>> http://mapguide.ca/sydney/ http://mapguide.ca/sydney/
>>>> regards
>>>> gordon
>>>> View this message in context:
>>>> http://n2.nabble.com/Virtual-Earth-and-Firefox-with-FUSION--tp3426002p3426002.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://n2.nabble.com/Virtual-Earth-and-Firefox-with-FUSION-tp3426002p3791581.html
View this message in context: http://n2.nabble.com/Virtual-Earth-and-Firefox-with-FUSION-tp3426002p3791892.html
