[mapguide-users] Impossible to select an object on map mapguide
euskalmap ziburudebian at free.fr
Mon Oct 12 03:40:50 EDT 2009
It is imposible to select polyline and the tooltip display in a buffer around
the object, not just only mouse over the object.
this case if the dataconnection is associated with an oracle view.
we had the problem just one time with a point layer (others points layers
with view run well)
never with polygon layer now
if the dataconnection is associated on the oracle table directly, it run
well : point, polyline, polygon.
Thanks for you help
Configuration :
PC Windows 2003 Server SP2
IIS 6
Mapguide OpenSource Server 2.0.2
Oracle 10g2
FDO King Oracle 0.8.10
View this message in context: http://n2.nabble.com/Impossible-to-select-an-object-on-map-mapguide-tp3806577p3806577.html
