[mapguide-users] PassData.php error
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Oct 12 20:15:30 EDT 2009
You're passing the correct arguments, right? There are about 7 or 8 to
pass in the InvokeURL command - they all have to be spelled correctly
and in the right case.
Andrew
Emily LaMunyon wrote:
> Hi all.
> I am still getting the following error when trying to use the
> Passdata.php script found on this site in Studio 2010. This happens
> when I select a feature and then hit a button to invoke the url. Has
> anyone seen this before?
> *Fatal error*: Uncaught exception 'mgobjectnotfoundexception' in
> *Unknown* on line *0, *
> *Thanks!*
> surv_seal1
> Emily LaMunyon
> GIS Analyst/Web Developer
> Salt Lake County Surveyor's Office
> (801) 468-2358
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
This e-mail message (including attachments, if any) is confidential and may be privileged. Any unauthorized distribution or disclosure is prohibited.  Disclosure to anyone other than the intended recipient does not constitute waiver of privilege.  If you have received this e-mail in error, please notify us and delete it and any attachments from your computer system and records.
Ce courriel (y compris  les pièces jointes) est confidentiel et peut être privilégié.  La distribution ou la divulgation non autorisée de ce courriel est interdite.  Sa divulgation à toute personne autre que son destinataire ne constitue pas une renonciation de privilège.  Si vous avez reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel, ainsi que les pièces jointes, de votre système informatique et de vos dossiers.
