[mapguide-users] PassData.php error
Emily LaMunyon
ELaMunyon at slco.org
Tue Oct 13 10:01:27 EDT 2009
Andrew,
Thank you so much for replying to my message. I am pretty new to this, so
there is a good chance I am doing it wrong.
Here are the arguments in my InvokeURL window.
Selected -> $CurrentSelection
DesiredField->Document_Num
URL->http://slcwwwmg/mapguide/map_search/report_survey.cfm
DestinationKeyName->Obj_Keys
Quotes->true
IsPost->true
LayerName->surveys
Did I miss some arguments? Do I need to make any changes to the original
PassData.php file?
Thanks!
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
DeMerchant
Sent: Monday, October 12, 2009 6:16 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] PassData.php error
You're passing the correct arguments, right? There are about 7 or 8 to pass
in the InvokeURL command - they all have to be spelled correctly and in the
right case.
Andrew
Emily LaMunyon wrote:
> Hi all.
> I am still getting the following error when trying to use the
> Passdata.php script found on this site in Studio 2010. This happens
> when I select a feature and then hit a button to invoke the url. Has
> anyone seen this before?
> *Fatal error*: Uncaught exception 'mgobjectnotfoundexception' in
> *Unknown* on line *0, *
> *Thanks!*
> surv_seal1
> Emily LaMunyon
> GIS Analyst/Web Developer
> Salt Lake County Surveyor's Office
> (801) 468-2358
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
