[mapguide-users] Can you save polygon data to an MS Access data?
JamesDudden jamesdudden at blueyonder.co.uk
Wed Oct 14 10:42:01 EDT 2009
I am storing x,y coordiantes in an MS Access database (using the .net
digitize sample) and then showing them as points on a map in MGOS2.0 via MG
Studio 09.
What I would like to do is store coordiantes for a polygon and then show
that on my map. Is this possible using MS Access?
If this is not possible in MS Access which database should I use?
Any help or advice is welcome
Regards
JD
http://www.software-matters.co.uk Software Matters  -
http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
Database  and Software Solutions
View this message in context: http://n2.nabble.com/Can-you-save-polygon-data-to-an-MS-Access-data-tp3823196p3823196.html
