[mapguide-users] Creating Tile Index Config Files - why do I lose
my coordinates?
JamesDudden
jamesdudden at blueyonder.co.uk
Wed Oct 14 10:07:08 EDT 2009
HI,
I am using MGOS 2.0 and multiple tifs with their corresponding tfws. I have
followed the "Creating Tile Index Config Files" instructions from the
FdoGdalNotes but always end up with an xml file with all coordinates set to
a default as below. Is there anything I can do to get the xml to show the
correct coordinates from the .tfw files. If i had to manually do this it
would take an age as I have 815 files.
Any help or advice is welcome
Regards
JD
<fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:gml="http://www.opengis.net/gml"
xmlns:fdo="http://fdo.osgeo.org/schemas"
xmlns:fds="http://fdo.osgeo.org/schemas/fds"><gml:DerivedCRS
gml:id="Default"><gml:metaDataProperty><gml:GenericMetaData><fdo:SCExtentType>dynamic</fdo:SCExtentType><fdo:XYTolerance>0.001000</fdo:XYTolerance><fdo:ZTolerance>0.001000</fdo:ZTolerance></gml:GenericMetaData></gml:metaDataProperty><gml:remarks>System
generated default FDO Spatial
Context</gml:remarks><gml:srsName>Default</gml:srsName><gml:validArea><gml:boundingBox><gml:pos>-10000000
-10000000</gml:pos><gml:pos>10000000
10000000</gml:pos></gml:boundingBox></gml:validArea><gml:baseCRS><fdo:WKTCRS
gml:id="Default"><gml:srsName>Default</gml:srsName><fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT></fdo:WKTCRS></gml:baseCRS><gml:definedByConversion
xlink:href="http://fdo.osgeo.org/coord_conversions#identity"/><gml:derivedCRSType
codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType><gml:usesCS
xlink:href="http://fdo.osgeo.org/cs#default_cartesian"/></gml:DerivedCRS><xs:schema
xmlns:default="http://fdo.osgeo.org/schemas/feature/default"
targetNamespace="http://fdo.osgeo.org/schemas/feature/default"
elementFormDefault="qualified"
attributeFormDefault="unqualified"><xs:annotation><xs:appinfo
source="http://fdo.osgeo.org/schemas"/></xs:annotation><xs:element
name="default" type="default:defaultType" abstract="false"
substitutionGroup="gml:_Feature"><xs:key name="defaultKey"><xs:selector
xpath=".//default"/><xs:field
xpath="FeatId"/></xs:key></xs:element><xs:complexType name="defaultType"
abstract="false" fdo:hasGeometry="false"><xs:annotation><xs:appinfo
source="http://fdo.osgeo.org/schemas"/></xs:annotation><xs:complexContent><xs:extension
base="gml:AbstractFeatureType"><xs:sequence><xs:element
name="FeatId"><xs:annotation><xs:appinfo
source="http://fdo.osgeo.org/schemas"/></xs:annotation><xs:simpleType><xs:restriction
base="xs:string"><xs:maxLength
value="256"/></xs:restriction></xs:simpleType></xs:element><xs:element
name="Image" type="fdo:RasterPropertyType" fdo:defaultImageXSize="1024"
fdo:defaultImageYSize="1024"
fdo:srsName="Default"><xs:annotation><xs:appinfo
source="http://fdo.osgeo.org/schemas"><fdo:DefaultDataModel
dataModelType="Bitonal" dataType="Unknown" organization="Pixel"
bitsPerPixel="1" tileSizeX="256"
tileSizeY="256"/></xs:appinfo></xs:annotation></xs:element></xs:sequence></xs:extension></xs:complexContent></xs:complexType></xs:schema><SchemaMapping
xmlns="http://fdogrfp.osgeo.org/schemas" provider="OSGeo.Gdal.3.2"
name="default"><complexType name="defaultType"><complexType
name="RasterTypeType"><RasterDefinition name="images"><Location name="D:\Map
Files\Tiffs\"><Feature name="ST00.tif"><Band name="RGB" number="1"><Image
frame="1"
name="ST00.tif"><Bounds><MinX>-10000000</MinX><MinY>-10000000</MinY><MaxX>10000000</MaxX><MaxY>10000000</MaxY></Bounds></Image></Band></Feature><Feature
name="ST00X.TIF"><Band name="RGB" number="1"><Image frame="1"
name="ST00X.TIF"><Bounds><MinX>-10000000</MinX><MinY>-10000000</MinY><MaxX>10000000</MaxX><MaxY>10000000</MaxY></Bounds></Image></Band></Feature><Feature
name="ST02.TIF"><Band name="RGB" number="1"><Image frame="1"
name="ST02.TIF"><Bounds><MinX>-10000000</MinX><MinY>-10000000</MinY><MaxX>10000000</MaxX><MaxY>10000000</MaxY></Bounds></Image></Band></Feature><Feature
name="ST04.TIF"><Band name="RGB" number="1"><Image frame="1"
name="ST04.TIF"><Bounds><MinX>-10000000</MinX><MinY>-10000000</MinY><MaxX>10000000</MaxX><MaxY>10000000</MaxY></Bounds></Image></Band>
http://www.software-matters.co.uk Software Matters -
http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
Database and Software Solutions
View this message in context: http://n2.nabble.com/Creating-Tile-Index-Config-Files-why-do-I-lose-my-coordinates-tp3822953p3822953.html
