[mapguide-users] Can't connect to MySQL
Ed Jobe
ed57gmc-bus at yahoo.com
Tue Oct 20 10:09:12 EDT 2009
I had already tried sp1, the second link and a file search only finds msvcr80.dll. As far as the mg msi goes, I did get prompted, but I did the repair by re-running the msi, not from Control Panel. After that install, ver 9 is still not there. I may have to try again, but this time, in addition to an uninstall, make sure the install dir's are clean.
Ed Jobe
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Monday, October 19, 2009 8:10:49 PM
Subject: Re: [mapguide-users] Can't connect to MySQL
Try installing these; see if it makes a difference:
http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displaylang=en
http://www.microsoft.com/downloads/details.aspx?familyid=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en
Only the second should be required (because that's what MG was built using) but...
As an aside, MG 2.1 will not re-install the runtime in a repair install; it's done during the bootstrap phase and is not part of the MSI.
Jason
2009/10/19 Ed Jobe <ed57gmc-bus at yahoo.com>
I uninstalled the runtime, rebooted, and did a repair of mapguide so it would install the redistributable from the setup package and I depends still show all the provider dll's look for version 9.
>Ed Jobe
>To: mapguide-users at lists.osgeo.org
>Sent: Monday, October 19, 2009 7:29:16 PM
>It says that for mysqlprovider.dll, msvcr90.dll is missing. I did a windows
>update and the latest for the c++ runtime is msvcr80.dll.
>View this message in context: http://n2.nabble.com/Can-t-connect-to-MySQL-tp3842847p3856390.html
>Sent from the MapGuide Users mailing list archive at Nabble.com.
>_______________________________________________
>mapguide-users mailing list
>http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091020/ea64200a/attachment.html
