[mapguide-users] Can't connect to MySQL
Jack Lee
jack.lee at sympatico.ca
Tue Oct 20 21:33:51 EDT 2009
Hi Ed,
Did you search for msvcr90.dll under %windir%\winsxs?
If the file exists, the problem might be that the MySQL provider was
built with a version that is incompatible with your version of MySQL.
Which version of MySQL are you using?
Ed Jobe wrote:
> I had already tried sp1, the second link and a file search only finds
> msvcr80.dll. As far as the mg msi goes, I did get prompted, but I did
> the repair by re-running the msi, not from Control Panel. After that
> install, ver 9 is still not there. I may have to try again, but this
> time, in addition to an uninstall, make sure the install dir's are clean.
> Ed Jobe
> *From:* Jason Birch <jason at jasonbirch.com>
> *To:* MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> *Sent:* Monday, October 19, 2009 8:10:49 PM
> *Subject:* Re: [mapguide-users] Can't connect to MySQL
> Try installing these; see if it makes a difference:
> http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displaylang=en
> http://www.microsoft.com/downloads/details.aspx?familyid=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en
> Only the second should be required (because that's what MG was built
> using) but...
> As an aside, MG 2.1 will not re-install the runtime in a repair
> install; it's done during the bootstrap phase and is not part of the MSI.
> Jason
> 2009/10/19 Ed Jobe <ed57gmc-bus at yahoo.com <mailto:ed57gmc-bus at yahoo.com>>
> I uninstalled the runtime, rebooted, and did a repair of mapguide
> so it would install the redistributable from the setup package and
> I depends still show all the provider dll's look for version 9.
> Ed Jobe
> *From:* Ed Jobe <ed57gmc-bus at yahoo.com <mailto:ed57gmc-bus at yahoo.com>>
> *To:* mapguide-users at lists.osgeo.org
> <mailto:mapguide-users at lists.osgeo.org>
> *Sent:* Monday, October 19, 2009 7:29:16 PM
> It says that for mysqlprovider.dll, msvcr90.dll is missing. I did
> a windows
> update and the latest for the c++ runtime is msvcr80.dll.
> http://n2.nabble.com/Can-t-connect-to-MySQL-tp3842847p3856390.html
> Sent from the MapGuide Users mailing list archive at Nabble.com
> <http://nabble.com/>.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091020/b8e973c7/attachment.html
