[mapguide-users] Zoom to a coordinate in fusion
Rico van Driel
rico at giskit.nl
Wed Oct 21 03:39:10 EDT 2009
Hi list,
A former colleague of mine had programmed a little php application where you can search for an address and zoom to the coordinates of the address. In a form you can type a search string and press 'search'. The application searches a database and gives a result in a list. When a user select a result, coordinates from the database are used to zoom in mapguide. See for an example http://mapguide2.gisnet.nl/sites/Zoeterwoude/index.php
Now someone else want to use the same functionality in a fusion environment. The current application is not working in a fusion environment because the zoom function needs to be updated. Somehow I can't find the code to do this correctly. My knowledge of PHP, javascript, fusion and so is limited. I hope some knows how to do this or where I can find a useful example.
>From the old source code the following function will do the zooming. The XC and YC are coordinates from the database.
<script>
function showAdres(value)
// alert(window.top.ViewerFrame.mapFrame.name);
ar = value.split("-");
xc = ar[0];
yc = ar[1];
// alert(xc);
window.top.ViewerFrame.mapFrame.ZoomToView(xc,yc,500,true);
</script>
I want to run the application in the taskpane part in this site
http://mapguide2.gisnet.nl/sites/dinkelland/dinkelland.php
met vriendelijke groet,
GISkit BV
Rico van Driel
GISkit BV
Postbus 489
3990 GG Houten
De Molen 15
3994 DA Houten
Tel: 030-6340430
Fax: 030-6342433
email: info at giskit.nl<mailto:info at giskit.nl>
www: http://www.giskit.nl<http://www.giskit.nl/>
Op al onze aanbiedingen en overeenkomsten zijn de algemene voorwaarden van FENIT, gedeponeerd ter Griffie van de Arrondissementsrechtbank te Den Haag op 3 juni 2003 onder nummer 60/2003 van toepassing. Een exemplaar zenden wij u desgewenst kosteloos toe.<blocked::http://www.giskit.nl/>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091021/1a00edd0/attachment.html
