[mapguide-users] Can't connect to MySQL
Jack Lee
jack.lee at sympatico.ca
Wed Oct 21 06:49:41 EDT 2009
Hi Ed,
depends does not necessary find the crt dlls even if it exists.
I think the MySQL provider was built with 5.0.x which is not compatible
with the 5.1.x client.
Ed Jobe wrote:
> Its not directly under winsxs, but in a subdir of that folder.
> %windir%\winsxs\C:\Windows\winsxs\amd64_microsoft.vc90.crt_.....
> I'm using mysql 5.1.37
> Still though, if I run depends.exe on mysqlprovider.dll, it can't find
> msvcr90.dll. So I don't think its an issue with the version of mysql
> because the dll should have shipped with mapguide.
> Ed Jobe
> *From:* Jack Lee <jack.lee at sympatico.ca>
> *To:* MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> *Sent:* Tuesday, October 20, 2009 6:33:51 PM
> *Subject:* Re: [mapguide-users] Can't connect to MySQL
> Hi Ed,
> Did you search for msvcr90.dll under %windir%\winsxs?
> If the file exists, the problem might be that the MySQL provider was
> built with a version that is incompatible with your version of MySQL.
> Which version of MySQL are you using?
> Ed Jobe wrote:
>> I had already tried sp1, the second link and a file search only finds
>> msvcr80.dll. As far as the mg msi goes, I did get prompted, but I did
>> the repair by re-running the msi, not from Control Panel. After that
>> install, ver 9 is still not there. I may have to try again, but this
>> time, in addition to an uninstall, make sure the install dir's are clean.
>> Ed Jobe
>> *From:* Jason Birch <jason at jasonbirch.com>
>> *Sent:* Monday, October 19, 2009 8:10:49 PM
>> Try installing these; see if it makes a difference:
>> http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displaylang=en
>> http://www.microsoft.com/downloads/details.aspx?familyid=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en
>> Only the second should be required (because that's what MG was built
>> using) but...
>> As an aside, MG 2.1 will not re-install the runtime in a repair
>> install; it's done during the bootstrap phase and is not part of the MSI.
>> Jason
>> 2009/10/19 Ed Jobe <ed57gmc-bus at yahoo.com <mailto:ed57gmc-bus at yahoo.com>>
>> I uninstalled the runtime, rebooted, and did a repair of mapguide
>> so it would install the redistributable from the setup package
>> and I depends still show all the provider dll's look for version 9.
>> Ed Jobe
>> *From:* Ed Jobe <ed57gmc-bus at yahoo.com
>> *To:* mapguide-users at lists.osgeo.org
>> <mailto:mapguide-users at lists.osgeo.org>
>> *Sent:* Monday, October 19, 2009 7:29:16 PM
>> It says that for mysqlprovider.dll, msvcr90.dll is missing. I did
>> a windows
>> update and the latest for the c++ runtime is msvcr80.dll.
>> View this message in context:
>> http://n2.nabble.com/Can-t-connect-to-MySQL-tp3842847p3856390.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com
>> <http://nabble.com/>.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091021/00f0fdcc/attachment.html
