[mapguide-users] Can't connect to MySQL
Ed Jobe ed57gmc-bus at yahoo.com
Wed Oct 21 10:43:27 EDT 2009
Then I'll try going back to 5.0.
Ed Jobe
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Wednesday, October 21, 2009 3:49:41 AM
Subject: Re: [mapguide-users] Can't connect to MySQL
Hi Ed,
depends does not necessary find the crt dlls even if it exists.
I think the MySQL provider was built with 5.0.x which is not compatible with the 5.1.x client.
Ed Jobe wrote:
Its not directly under winsxs, but in a subdir of that folder.
>%windir%\winsxs\C:\Windows\winsxs\amd64_microsoft.vc90.crt_.....
>I'm using mysql 5.1.37
>Still though, if I run depends.exe on mysqlprovider.dll, it can't find msvcr90.dll. So I don't think its an issue with the version of mysql because the dll should have shipped with mapguide.
>Ed Jobe
>Sent: Tuesday, October 20, 2009 6:33:51 PM
>Hi Ed,
>Did you search for msvcr90.dll under %windir%\winsxs?
>If the file exists, the problem might be that the MySQL provider was built with a version that is incompatible with your version of MySQL. Which version of MySQL are you using?
>Ed Jobe wrote:
>I had already tried sp1, the second link and a file search only finds msvcr80.dll. As far as the mg msi goes, I did get prompted, but I did the repair by re-running the msi, not from Control Panel. After that install, ver 9 is still not there. I may have to try again, but this time, in addition to an uninstall, make sure the install dir's are clean.
>>Ed Jobe
>>Sent: Monday, October 19, 2009 8:10:49 PM
>>Try installing these; see if it makes a difference:
>>http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displaylang=en
>>http://www.microsoft.com/downloads/details.aspx?familyid=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en
>>Only the second should be required (because that's what MG was built using) but...
>>As an aside, MG 2.1 will not re-install the runtime in a repair install; it's done during the bootstrap phase and is not part of the MSI.
>>Jason
>>2009/10/19 Ed Jobe <ed57gmc-bus at yahoo.com>
>>I uninstalled the runtime, rebooted, and did a repair of mapguide so it would install the redistributable from the setup package and I depends still show all the provider dll's look for version 9.
>>>Ed Jobe
>>>To: mapguide-users at lists.osgeo.org
>>>Sent: Monday, October 19, 2009 7:29:16 PM
>>>It says that for mysqlprovider.dll, msvcr90.dll is missing. I did a windows
>>>update and the latest for the c++ runtime is msvcr80.dll.
>>>View this message in context: http://n2.nabble.com/Can-t-connect-to-MySQL-tp3842847p3856390.html
>>>Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>_______________________________________________
>>>mapguide-users mailing list
>>>http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091021/4cf9e413/attachment.html
