[mapguide-users] Add features to SQL Server Spatial
Gunter Becker
gunter.becker at csogis.de
Fri Oct 23 07:24:39 EDT 2009
i'm trying to add features to an existing FeatureSource via MapGuide API.
I've created a new schema with Autodesk Map 2010, created some polygons,
created my feature source and layer in MapGuide Studio, inserted the layer
in my map and it shows up fine.
OK, displaying the features works fine. But when trying to add some features
via the digitize function and my serverside code nothing happens. It seemes
that the code works fine, cause it is the same code that I use with sdf
feature sources and the code throws no error in debug mode. The
"UpdateFeatures"-Methode seems to work but when looking into the SQL Server
table there is no entry and therefore no object on the map. When logging
SQL-Statements with SQL Profiler no activities were logged.
Only thing that works is deleting an existing map from the featuresource. So
maybe it has to do something with the coordinatesystem? But as far as I
understand the geometry-column of my databasetable doesn't need a
coordinatesystem assigned!
Someone who had same problem? Any ideas?
Thanks, Gunter
View this message in context: http://n2.nabble.com/Add-features-to-SQL-Server-Spatial-tp3878130p3878130.html
