[mapguide-users] Add features to SQL Server Spatial
Gunter Becker gunter.becker at csogis.de
Mon Oct 26 14:52:57 EDT 2009
Is there at least anyone who had successfully added features to SQL Server
2008 Spatial with the MapGuide API. What could cause problems when adding
features to the database?
I think there was another thread (
http://n2.nabble.com/MSSqlServer-Spatial-problem-tt3148712.html#a3154109
MSSqlServer Spatial problem ) that describes a similar problem.
But this problem had to do with 3-dimensional point what is not what i am
using. I am using x,y-points.
Any ideas?
Gunter
Gunter Becker wrote:
> Hi,
> i'm trying to add features to an existing FeatureSource via MapGuide API.
> I've created a new schema with Autodesk Map 2010, created some polygons,
> created my feature source and layer in MapGuide Studio, inserted the layer
> in my map and it shows up fine.
> OK, displaying the features works fine. But when trying to add some
> features via the digitize function and my serverside code nothing happens.
> It seemes that the code works fine, cause it is the same code that I use
> with sdf feature sources and the code throws no error in debug mode. The
> "UpdateFeatures"-Methode seems to work but when looking into the SQL
> Server table there is no entry and therefore no object on the map. When
> logging SQL-Statements with SQL Profiler no activities were logged.
> Only thing that works is deleting an existing map from the featuresource.
> So maybe it has to do something with the coordinatesystem? But as far as I
> understand the geometry-column of my databasetable doesn't need a
> coordinatesystem assigned!
> Someone who had same problem? Any ideas?
> Thanks, Gunter
View this message in context: http://n2.nabble.com/Add-features-to-SQL-Server-Spatial-tp3878130p3894197.html
