[mapguide-users] symbols in tiled maps
A H
hizperion at hotmail.com
Tue Oct 27 22:05:17 EDT 2009
i'm using MGOS 1.2 and MapGuide Studio 2008. i wanted to define a tiled map
using Studio. i have several layers, some of them are area layers, and some
are point layers.
the problem is the symbols in this point layers doesn't appear on the map
when i set it as Base layers to make a tiled map. only labels are displayed.
i think this is a limitation, but is there any way to get around it?
it could work if i use the Ajax viewer if i have both normal layers and base
layers, but i'm trying to use this map in OpenLayers. if i set the layers
with symbols as normal layers (not as base layers), i don't know how to
define it in OpenLayers.
View this message in context: http://n2.nabble.com/symbols-in-tiled-maps-tp3903114p3903114.html
