[mapguide-users] symbols in tiled maps
Zac Spitzer zac.spitzer at gmail.com
Tue Oct 27 22:09:51 EDT 2009
well, 1.2 is pretty old, can you try this out the 2.0.2 release or the
unoffical 2.1 beta?
if it's been resolved in subsequent versions, it's very unlikely to be
backported
ith regards to OL, you would just have two layers to the map?
On Wed, Oct 28, 2009 at 1:05 PM, A H <hizperion at hotmail.com> wrote:
> i'm using MGOS 1.2 and MapGuide Studio 2008. i wanted to define a tiled map
> using Studio. i have several layers, some of them are area layers, and some
> are point layers.
> the problem is the symbols in this point layers doesn't appear on the map
> when i set it as Base layers to make a tiled map. only labels are
> displayed.
> i think this is a limitation, but is there any way to get around it?
> it could work if i use the Ajax viewer if i have both normal layers and
> base
> layers, but i'm trying to use this map in OpenLayers. if i set the layers
> with symbols as normal layers (not as base layers), i don't know how to
> define it in OpenLayers.
> http://n2.nabble.com/symbols-in-tiled-maps-tp3903114p3903114.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091028/583799d2/attachment.html
