[mapguide-users] symbols in tiled maps
A H hizperion at hotmail.com
Tue Oct 27 23:56:43 EDT 2009
yeah.. but all the samples i looked only use Base Layer Group when using
tiled map :(
or is it the one called dynamicLayer in
http://trac.osgeo.org/mapguide/attachment/wiki/CodeSamples/JavaScript/OpenlayersExample/sheboygan.php
the resource problem should be solved in 2.1, since i've been tracking the
ticket too.
zspitzer wrote:
> did you have a look at
> http://trac.osgeo.org/mapguide/wiki/CodeSamples/JavaScript/OpenlayersExample
> i'm pretty sure that problem was resolved in 2.1
> On Wed, Oct 28, 2009 at 1:39 PM, A H <hizperion at hotmail.com> wrote:
>> my system have a problem with 2.0 versions regarding the feature still
>> being
>> locked after its updated i think (i forgot the details, but i will try
>> upgrading it soon), and i'm trying to save hassle installing/uninstalling
>> beta version in the production servers (didn't know that it will take
>> this
>> long for 2.1).
>> could you help me with OpenLayers definition to add more layers in?
>> this is a piece of the OL function
>>            function initTiled(){
>>            var extent = new
>> OpenLayers.Bounds(85.000000,-11.000000,130.000000,19.000000);
>>            var tempScales =
>> [500,994.13360,1976.60324,3930.01542,7813.92080,15536.16253,30890.04252,61417.65868,122114.71687,242796.68742,482744.69230,959825.44253,1908389.45481,3794388.17705,7544257.59473,15000000];
>>            var mapOptions = {
>>                maxExtent: extent,
>>                scales: tempScales,
>>                                controls: [
>>                        new OpenLayers.Control.Navigation(),
>>                        new OpenLayers.Control.PanZoomBar(),
>>                        new OpenLayers.Control.Permalink(),
>>                        new OpenLayers.Control.ScaleLine(),
>>                        new OpenLayers.Control.Permalink('permalink'),
>>                        new OpenLayers.Control.MousePosition(),
>>                        new OpenLayers.Control.OverviewMap()
>>            map = new OpenLayers.Map( 'mapT', mapOptions );
>>            var params = {
>>              mapdefinition:
>> 'Library://World/Maps/worldmap_tiled.MapDefinition',
>>              basemaplayergroupname: "Base Layer Group"
>>            var options = {
>>              singleTile: false
>>            var layer = new OpenLayers.Layer.MapGuide( "MapGuide OS tiled
>> layer", url, params, options );
>>            map.addLayer(layer);
>> thank you for your reply.
>> zspitzer wrote:
>> > well, 1.2 is pretty old, can you try this out the 2.0.2 release or the
>> > unoffical 2.1 beta?
>> > if it's been resolved in subsequent versions, it's very unlikely to be
>> > backported
>> > ith regards to OL, you would just have two layers to the map?
>> > On Wed, Oct 28, 2009 at 1:05 PM, A H <hizperion at hotmail.com> wrote:
>> >> i'm using MGOS 1.2 and MapGuide Studio 2008. i wanted to define a
>> tiled
>> >> map
>> >> using Studio. i have several layers, some of them are area layers, and
>> >> some
>> >> are point layers.
>> >> the problem is the symbols in this point layers doesn't appear on the
>> map
>> >> when i set it as Base layers to make a tiled map. only labels are
>> >> displayed.
>> >> i think this is a limitation, but is there any way to get around it?
>> >> it could work if i use the Ajax viewer if i have both normal layers
>> and
>> >> base
>> >> layers, but i'm trying to use this map in OpenLayers. if i set the
>> layers
>> >> with symbols as normal layers (not as base layers), i don't know how
>> to
>> >> define it in OpenLayers.
>> >> View this message in context:
>> >> http://n2.nabble.com/symbols-in-tiled-maps-tp3903114p3903114.html
>> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> mapguide-users mailing list
>> >> mapguide-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> > Zac Spitzer -
>> > http://zacster.blogspot.com
>> > +61 405 847 168
>> http://n2.nabble.com/symbols-in-tiled-maps-tp3903114p3903225.html
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://n2.nabble.com/symbols-in-tiled-maps-tp3903114p3903460.html
