[mapguide-users] symbols in tiled maps
Zac Spitzer zac.spitzer at gmail.com
Tue Oct 27 23:58:08 EDT 2009
yep the dynamic layer one
On Wed, Oct 28, 2009 at 2:56 PM, A H <hizperion at hotmail.com> wrote:
> yeah.. but all the samples i looked only use Base Layer Group when using
> tiled map :(
> or is it the one called dynamicLayer in
> http://trac.osgeo.org/mapguide/attachment/wiki/CodeSamples/JavaScript/OpenlayersExample/sheboygan.php
> the resource problem should be solved in 2.1, since i've been tracking the
> ticket too.
> zspitzer wrote:
> > did you have a look at
> http://trac.osgeo.org/mapguide/wiki/CodeSamples/JavaScript/OpenlayersExample
> > i'm pretty sure that problem was resolved in 2.1
> > On Wed, Oct 28, 2009 at 1:39 PM, A H <hizperion at hotmail.com> wrote:
> >> my system have a problem with 2.0 versions regarding the feature still
> >> being
> >> locked after its updated i think (i forgot the details, but i will try
> >> upgrading it soon), and i'm trying to save hassle
> installing/uninstalling
> >> beta version in the production servers (didn't know that it will take
> >> this
> >> long for 2.1).
> >> could you help me with OpenLayers definition to add more layers in?
> >> this is a piece of the OL function
> >>            function initTiled(){
> >>            var extent = new
> >> OpenLayers.Bounds(85.000000,-11.000000,130.000000,19.000000);
> >>            var tempScales =
> [500,994.13360,1976.60324,3930.01542,7813.92080,15536.16253,30890.04252,61417.65868,122114.71687,242796.68742,482744.69230,959825.44253,1908389.45481,3794388.17705,7544257.59473,15000000];
> >>            var mapOptions = {
> >>                maxExtent: extent,
> >>                scales: tempScales,
> >>                                controls: [
> >>                        new OpenLayers.Control.Navigation(),
> >>                        new OpenLayers.Control.PanZoomBar(),
> >>                        new OpenLayers.Control.Permalink(),
> >>                        new OpenLayers.Control.ScaleLine(),
> >>                        new OpenLayers.Control.Permalink('permalink'),
> >>                        new OpenLayers.Control.MousePosition(),
> >>                        new OpenLayers.Control.OverviewMap()
> >>            map = new OpenLayers.Map( 'mapT', mapOptions );
> >>            var params = {
> >>              mapdefinition:
> >> 'Library://World/Maps/worldmap_tiled.MapDefinition',
> >>              basemaplayergroupname: "Base Layer Group"
> >>            var options = {
> >>              singleTile: false
> >>            var layer = new OpenLayers.Layer.MapGuide( "MapGuide OS tiled
> >> layer", url, params, options );
> >>            map.addLayer(layer);
> >> thank you for your reply.
> >> zspitzer wrote:
> >> > well, 1.2 is pretty old, can you try this out the 2.0.2 release or the
> >> > unoffical 2.1 beta?
> >> > if it's been resolved in subsequent versions, it's very unlikely to be
> >> > backported
> >> > ith regards to OL, you would just have two layers to the map?
> >> > On Wed, Oct 28, 2009 at 1:05 PM, A H <hizperion at hotmail.com> wrote:
> >> >> i'm using MGOS 1.2 and MapGuide Studio 2008. i wanted to define a
> >> tiled
> >> >> map
> >> >> using Studio. i have several layers, some of them are area layers,
> and
> >> >> some
> >> >> are point layers.
> >> >> the problem is the symbols in this point layers doesn't appear on the
> >> map
> >> >> when i set it as Base layers to make a tiled map. only labels are
> >> >> displayed.
> >> >> i think this is a limitation, but is there any way to get around it?
> >> >> it could work if i use the Ajax viewer if i have both normal layers
> >> and
> >> >> base
> >> >> layers, but i'm trying to use this map in OpenLayers. if i set the
> >> layers
> >> >> with symbols as normal layers (not as base layers), i don't know how
> >> to
> >> >> define it in OpenLayers.
> >> >> View this message in context:
> >> >> http://n2.nabble.com/symbols-in-tiled-maps-tp3903114p3903114.html
> >> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> >> >> _______________________________________________
> >> >> mapguide-users mailing list
> >> >> mapguide-users at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >> > Zac Spitzer -
> >> > http://zacster.blogspot.com
> >> > +61 405 847 168
> >> http://n2.nabble.com/symbols-in-tiled-maps-tp3903114p3903225.html
> > Zac Spitzer -
> > +61 405 847 168
> http://n2.nabble.com/symbols-in-tiled-maps-tp3903114p3903460.html
Zac Spitzer -
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091028/dc00d967/attachment.html
