[mapguide-users] How to avoid CTRL+click action
JamesDudden jamesdudden at blueyonder.co.uk
Fri Oct 30 05:49:52 EDT 2009
Nisha P wrote:
> Is there any possibility to avoid CTRL  by not affecting the working of
> the
> tools?
It sounds your code is worng. If your map or any of the map's tools aren't
working then you must have made a mistake when editing ajaxmappane.templ -
if I were you I would put the original ajaxmappane.templ back and get
everything working again and then post your code and we can try and help you
get it working.
Regards
JD
http://www.software-matters.co.uk Software Matters  -
http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
Database  and Software Solutions
View this message in context: http://n2.nabble.com/How-to-avoid-CTRL-click-action-tp3910071p3917926.html
