[mapguide-users] Symbolization is not well-represented in legend
Rodolfo Moreno rodolfoamoreno at gmail.com
Fri Oct 30 13:32:33 EDT 2009
Sorry I forget to mention that the layer with this issue is called newplaces
in the first post and newplaces1 in the second post.
Regards,
Rodolfo Moreno wrote:
> The hospital layer (blue rectangle with a "H" inside). In the map is
> displayed correctly however in the legend just a blue rectangle is showed.
> In this case the graphic symbol is a PATH. When the graphic symbol is a
> IMAGE then both the map and the legend are showed correctly (see the
> attached image)
> Regards,
> zspitzer wrote:
>> which layer is the issue in the legend?
>> On Fri, Oct 30, 2009 at 4:45 AM, Rodolfo Moreno
>> <rodolfoamoreno at gmail.com>wrote:
>>> Hi All, I have been testing the symbolization in MGOS 2.0.2 using the
>>> new
>>> CompositeTypeStyle TAG added in layerdefinition 1.1.0. So when I
>>> displayed
>>> the map with this new symbolization I realize that the symbols are OK in
>>> the
>>> map but not in the legend.
>>> I have attached an image to see what I am saying.
>>> has anyone seen this issue?
>>> http://n2.nabble.com/file/n3914416/HospitalSymbol.jpg
>>> Rodolfo Moreno
>>> CivilEng
>>> View this message in context:
>>> http://n2.nabble.com/Symbolization-is-not-well-represented-in-legend-tp3914416p3914416.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
>  http://n2.nabble.com/file/n3920348/hospitalSymbol.jpg
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Symbolization-is-not-well-represented-in-legend-tp3914416p3920365.html
