[mapguide-users] Mapguide Site URL
Nichols, Mark A.
markn at spicergroup.com
Tue Sep 1 16:21:44 EDT 2009
Mark, I'm not sure if I'm understanding your question, but if you put the sample files in place (just web files, not the sample library) and then modify the file ajaxviewersample.php (I think that's the name of it) and change the weblayout line to your weblayout of what you created you'll be fine. Rename the file to something else, maybe index.php so it not an odd name.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org on behalf of Mark Hedges
Sent: Tue 9/1/2009 3:20 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Mapguide Site URL
Mark,
I see what you are telling me but,
I created my entire site without using any of the samples. I did this in
order to not clutter my data set.
With that said do you know the name of the php file I will have to modify in
my data set?
Thank you for your help.
Mark
Mark Nichols wrote:
> Mark,
> If you are using PHP, you can do the following:
> 1. Download phpviewersample.zip from
> http://mapguide.osgeo.org/download/releases/2.0.x-samples and extract it
> to
> the Web\www folder.
> 2. Modify your ajaxviewersample.php file to reflect your web layout.
> Here's an example below.
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Frameset//EN"
> "http://www.w3.org/TR/html4/frameset.dtd">
> <?php
> include 'utilityfunctions.php';
> MgInitializeWebTier($configFilePath);
> $site = new MgSite();
> $site->Open(new MgUserInformation('Anonymous', ''));
> $sessionId = $site->CreateSession();
> $webLayout = "Library://Folder/Maps and Layouts/Overview
> Map.WebLayout";
> <html>
> <head>
> <title>Viewer Sample Application</title>
> <meta content="text/html; charset=utf-8" http-equiv="Content-Type">
> </head>
> <frameset rows="50,*" frameborder="NO" border="0" framespacing="0">
> <frame src="title.html?AppName=AJAX" name="TitleFrame" scrolling="NO"
> noresize>
> <frame src="../mapviewerphp/ajaxviewer.php?SESSION=<?php echo
> $sessionId; ?>&WEBLAYOUT=<?php echo $webLayout; ?>" name="ViewerFrame">
> </frameset>
> </html>
> If you are not using PHP, I would assume you should use the same steps but
> with either the javaviewersample.zip or dotnetviewersample.zip.\
> I would be interested to know if anyone is doing it a different way!
> Mark
> On 9/1/09 11:13 AM, "Mark Hedges" <hedgesm at cityofnorthlasvegas.com> wrote:
>> I have finished configuring my Mapguide Enterprise 2010 site. In order
>> to
>> access the site I have bookmarked the address from the Web Layout under
>> the
>> "View in Browser" header. As you know the URL Address is very long,
>> (http://localhost:8008/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fNorth
>> +Las+Vegas%2fWeb+Layouts%2fNorth+Las+Vegas.WebLayout).
>> Could someone please explain how I go about changing the site URL Address
>> to
>> make more sense. Thank you in advance.
>> Mark
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/Mapguide-Site-URL-tp3561162p3562538.html
