[mapguide-users] Mixing lines and points in a single layer with
MGOS 2.1 and Fusion 2.0
GreenMapSanMiguel
webmaster at SMAmap.com
Wed Sep 2 14:03:41 EDT 2009
Is there anyway to control the drawing order when lines and points are in the
same layer? Currently the lines are on top of the points as you can see
here:
http://mapaverdesanmiguel.org/sanmigueldeallende/greenmap/en/index.php?locale=en&LAYER=hikes&LOC=Rancho
Los Milagros
I would like the points to be on top of the lines. I've tried changing the
order of the definitions in the XML, but it doesn't seem to make a
difference. Is there anyway to control this?
Thanks!
View this message in context: http://n2.nabble.com/Mixing-lines-and-points-in-a-single-layer-with-MGOS-2-1-and-Fusion-2-0-tp3568444p3568444.html
