[mapguide-users] Mixing lines and points in a single layer with
MGOS 2.1 and Fusion 2.0
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Sep 3 04:42:21 EDT 2009
AFAIK, the render just reads records from the dataset, and draws them in
that order.
If you are able to sort your datasource, you could make it work.
If not, you have to make multiple layers, each displaying one type of
geometry.
If you search trac, there are some discussions about this situation.
Regards, Kenneth Skovhede, GEOGRAF A/S
GreenMapSanMiguel skrev:
> Is there anyway to control the drawing order when lines and points are in the
> same layer? Currently the lines are on top of the points as you can see
> here:
> http://mapaverdesanmiguel.org/sanmigueldeallende/greenmap/en/index.php?locale=en&LAYER=hikes&LOC=Rancho
> Los Milagros
> I would like the points to be on top of the lines. I've tried changing the
> order of the definitions in the XML, but it doesn't seem to make a
> difference. Is there anyway to control this?
> Thanks!
