[mapguide-users] Mixing lines and points in a single layer with
MGOS 2.1 and Fusion 2.0
Zac Spitzer
zac.spitzer at gmail.com
Thu Sep 3 04:51:34 EDT 2009
what you really help here is RFC 69 :)
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc69
On Thu, Sep 3, 2009 at 6:42 PM, Kenneth Skovhede, GEOGRAF
A/S<ks at geograf.dk> wrote:
> AFAIK, the render just reads records from the dataset, and draws them in
> that order.
> If you are able to sort your datasource, you could make it work.
> If not, you have to make multiple layers, each displaying one type of
> geometry.
> If you search trac, there are some discussions about this situation.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> GreenMapSanMiguel skrev:
>> Is there anyway to control the drawing order when lines and points are in
>> the
>> same layer? Currently the lines are on top of the points as you can see
>> here:
>> http://mapaverdesanmiguel.org/sanmigueldeallende/greenmap/en/index.php?locale=en&LAYER=hikes&LOC=Rancho
>> Los Milagros
>> I would like the points to be on top of the lines. I've tried changing
>> the
>> order of the definitions in the XML, but it doesn't seem to make a
>> difference. Is there anyway to control this?
>> Thanks!
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
