[mapguide-users] Error with MGOS 2.0 and Fusion
Zac Spitzer
zac.spitzer at gmail.com
Mon Sep 7 02:17:54 EDT 2009
are you using the 2.0.2 build with the latest updated build from the
fusion website?
http://trac.osgeo.org/fusion/wiki/GetIt
unfortunately to date mapguide has a very slow release cycle and there
is a some manual updating required to have a nice stable build
hopefully now that there is a nightly build process being put in place and
the introduction of sandboxes, the mapguide project will move towards
having more frequent point releases
2.1 has been in beta for ages, there mapguide server side is greatly improved
but it's being held up by fusion..
As your request is fusion specific, perhaps posting to the fusion mailing
list would also be more specific..
with regards to your question about feedback, keep in mind everyone
is probably busy working on their own projects...
a small snippets of code is very hard to debug, posting a complete script
or a live url makes it easier for someone else to review your problem
z
On Mon, Sep 7, 2009 at 4:00 PM, Andre Schoonbee<andresch at iway.na> wrote:
> Hi Guys
> I have submited this question, but to dat, have not received any feedback. I
> am certain, there's a lot of persons, capable of helping and guiding me. A
> Bit disapointing to see no responce coming. I guess it is fir this reason
> why the general public tends to stay away from Open Source?
> Andre
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andre Schoonbee
> Sent: 04 September 2009 10:48 AM
> To: 'MapGuide Users Mail List'
> Subject: [mapguide-users] Error with MGOS 2.0 and Fusion
> Importance: High
> I'm trying to create a custom query for a layer filtering when the map
> loads. Basically the code I'm executing in the var fusionInitialized
> function is:
> var map = Fusion.getWidgetById('Map');
> var options = {};
> options.maxFeatures = 0;
> options.layers = '(Points)';
> options.filter = '(PointNr LIKE \'%007%\')';
> map.query(options);
> However, the query execution throws an exception:
> Fusion Error:
> WARNING: Exception occurred in AJAX callback.
> Message: invalid label
> Location: http://localhost:8008/mapguide/fusion/MapGuide/MapGuide.js (774)
> Response: ERROR: Argument is null.
> Argument is null.
> Exception occurred in method MgResourceIdentifier.CheckName at line 624 in
> file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\platformbase\Ser
> vices/ResourceIdentifier.cpp
> - MgMap.Open line 457 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecommon\M
> apLayer/Map.cpp
> - MgResourceIdentifier.CheckName line 624 file
> I have debugged the query process from MapGuide.js - query :
> function(options) - adding the alert massage as shown below:
> var ajaxOptions = {
> onSuccess: OpenLayers.Function.bind(this.processQueryResults,
> this, zoomTo),
> parameters: params};
> /* >>>>>> */ alert('mapname:
> '+params.mapname+'\nsessionid:'+params.sessionid+'\nlayers:
> '+params.layers+'\nfilter: '+params.filter);
> Fusion.ajaxRequest(loadmapScript, ajaxOptions);
> The message shows that at the execution of the query both the mapname and
> sessionid are not defined for the map
> mapname: undefined
> sessionid:undefined
> layers: (Points)
> filter: (PointNr LIKE '%007%')
> Q: Since the fusionInitialized is registered to be executed on
> Fusion.Event.FUSION_INITIALIZED, what is the problem with the above test ?
> My idea was that the map should have been fully loaded by then and the
> filter queried ok.
> Thank you,
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
