[mapguide-users] Two Raster Display Questions (Stretching
andRemoving Collars)
Darren Cope
darrencope at gmail.com
Tue Sep 8 21:19:59 EDT 2009
Hi Mark,
Sorry, upon re-reading my post I realize it was a bit unclear. The images
are not in fact bitonal. I only mentioned that I had tried the bitonal
setting to show that I had tried everything I can think of! However, my
interpretation of the "Transparency Colour" setting under Advanced in
Maestro was that it would perform a similar function for images that were
not bitonal. Perhaps I'm wrong in this interpretation?
Cheers,
Darren
Nichols, Mark A. wrote:
> Regarding your question about bitonal images. Yes, I've got them to work.
> See this previous post:
> http://n2.nabble.com/Bitonal-Image-Problem-td3156619.html
> It might take some work in Irfanview to get just the right export as png.
> Mark
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org on behalf of Darren Cope
> Sent: Tue 9/8/2009 7:40 AM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] Two Raster Display Questions (Stretching
> I'm still struggling after having tried everything I can think of. Is the
> only solution to pre-process the imagery via gdal or the like? If so,
> which
> command would I use to 'stretch' the histograms without actually modifying
> the pixel (elevation) values in the DEMs?
> Any thoughts on either question much appreciated.
> Cheers,
> Darren
> Darren Cope wrote:
>> Hi folks,
>> Two questions regarding raster display in MGOS:
>> 1. I have a set of DEMs from Geobase (approx. 100 tiles). I've created
>> a
>> Data Connection in Studio to the directory containing the images, and
>> then
>> a layer pointed at the data connection. However, because the max/min
>> values of each tile differ, they are not displayed using the same range.
>> How can I 'stretch' all tiles to the max/min of the entire set? Images
>> are in GeoTiff format if that matters.
>> 2. I have a set of SPOT imagery (also from GeoBase) that are set up in
>> the same way as above (except in ecw format). How do I remove the black
>> collars around the images? The Bitonal Image settings in Studio don't
>> seem to work, and the "Transparency Colour" under Advanced in Maestro
>> doesn't work either. Thoughts?
>> Thanks for your help!
> http://n2.nabble.com/Two-Raster-Display-Questions-Stretching-and-Removing-Collars-tp3525648p3602691.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/Two-Raster-Display-Questions-Stretching-and-Removing-Collars-tp3525648p3607463.html
