[mapguide-users] Fusion - Session ID invalid because the
session separator character was not found
Berdel, Brian
brian.berdel at mcmtrans.com
Fri Sep 11 09:11:38 EDT 2009
I updated the Taskpane.js file in the widgets folder to fix this issue. It does not pass the parameters on load without this code I believe I entered a ticket for this with new code a while back.
Change your setContent function to this:
setContent: function(url) {
if (this.nCurrentTask < this.aExecutedTasks.length) {
this.aExecutedTasks.splice(this.nCurrentTask, this.aExecutedTasks.length - this.nCurrentTask);
var map = this.getMap();
var params = []; params.push('LOCALE=' + Fusion.locale); params.push('SESSION=' + map.getSessionID()); params.push('MAPNAME=' + map.getMapName()); if (url.indexOf('?') < 0) {
url += '?';
} else if (url.slice(-1) != '&') {
url += '&';
} url += params.join('&');
this.aExecutedTasks.push(url);
++this.nCurrentTask;
this.iframe.src = url;
this.iframe.taskPaneId = this.widgetTag.name;
this.updateButtons();
Brian Berdel
McMahon Associates, Inc.
p: 215.283.9444 x 260
www.mcmtrans.com<http://www.mcmtrans.com>
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Fraser Burgess
Sent: Thursday, September 10, 2009 1:54 PM
To: MapGuide Users Mail List
Subject: [mapguide-users] Fusion - Session ID invalid because the session separator character was not found
Hi List.
I'm modifying the Ajax utility demo found here http://enterprise.mapguide.com/utilitymap/ . I made all my modifications and had my shiny new application up and running in a basic AJAX layout.
I'm now trying to move it across to a Fusion layout. All code works fine in the basic web layout, but in the Fusion layout I get the error below. So I guess the question is how does Fusion differ from Ajax when it comes to passing through a session ID? Any code out there that shows how this is done in fusion?
Further to this, if I get across this initial hurdle, are there a pile more waiting for me by taking something created for AJAX and cramming it into Fusion?
Thanks for your help.
Fraser
Invalid argument(s):
[1] = ""
The session ID is invalid because the session separator character was not found.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: OSGeo.MapGuide.MgInvalidArgumentException: Invalid argument(s):
[1] = ""
Source Error:
Line 34: this.args = incomingArgs;
Line 35: this.site = new MgSiteConnection();
Line 36: this.site.Open(new MgUserInformation(GetParameter(this.args, "session")));
Line 37: }
Line 38:
Important notice to recipients:
Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090911/b38fed19/attachment.html
