[mapguide-users] renderingService.RenderMap -symbols from my
symbol library do not render
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Sep 14 03:06:01 EDT 2009
Not sure if it helps you, but the AJAX viewer uses a
"RenderDynamicOverlay" to render layers that are not baselayers.
You should still get exactly the same results, but perhaps you can see
something if you try calling both methods.
Regards, Kenneth Skovhede, GEOGRAF A/S
djonio skrev:
> Howdy,
> MGOS 2.0.2
> Windows XP Sp2
> .NET
> Ajax
> I have a BaseLayerGroup comprised of one(1) MrSid. Works great.
> When I issue a: renderingService.RenderMap(map, selection,
> mapCenterCoordinate, mapScale, width, height, color, imageflavor.ToUpper());
> from codebehind to capture the current map image the BaseLayerGroup renders
> and my other layers render as expected; EXCEPT the symbols from my symbol
> library do not render.
> Again everything renders completely and correctly on the “interactive” map.
> Any thoughts?
> r,
> dennis
