[mapguide-users] Select an object in MapGuide 2.0.2
alba
a.penitente at gepaspa.com
Thu Sep 17 04:22:13 EDT 2009
hi all,
I use mapguide open source 2.0.2 on Windows XP and IIS
I have to select an object after the extraction, but
I tried in three different alternative ways but doesn't work
I use the following code.
Anyone can help me? My work is stopped!
thanks Alba
var mapWidgetId = 'Map';
var Fusion = window.top.Fusion;
var mapWidget = Fusion.getWidgetById(mapWidgetId);
function SelectFeature(){
selectionXml = reqHandler.responseText;
sel=TrimString(selectionXml);
//-- first mode-----------
var map = GetParent().Fusion.getMapByName(mapName);
map.setSelection(sel, true, true);
//-- second mode----------
GetParent().SetSelectionXML(sel);
//-- third mode----------
mapWidget.setSelection(sel, z);
alert(mapWidget.hasSelection());
function SetSelectionXML(selectionXml) {
var mapWidget = Fusion.getWidgetById('Map');
if (mapWidget && mapWidget.isMapLoaded()) {
mapWidget.setSelection(selectionXml, true, true);
function GetParent()
if(popup) {
return opener;
} else {
return parent.parent;
function TrimString(responseString)
responseString = responseString.replace( /^\s+/g, "" );
return responseString.replace( /\s+$/g, "" );
View this message in context: http://n2.nabble.com/Select-an-object-in-MapGuide-2-0-2-tp3661625p3661625.html
