[mapguide-users] Select an object in MapGuide 2.0.2
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Sep 17 08:23:35 EDT 2009
Are you certain that the xml you use is correct?
Do you remember to refresh the map?
Regards, Kenneth Skovhede, GEOGRAF A/S
alba skrev:
> hi all,
> I use mapguide open source 2.0.2 on Windows XP and IIS
> I have to select an object after the extraction, but
> I tried in three different alternative ways but  doesn't work
> I use the following code.
> Anyone can help me? My work is stopped!
> thanks Alba
> var mapWidgetId = 'Map';
> var Fusion = window.top.Fusion;
> var mapWidget = Fusion.getWidgetById(mapWidgetId);
> function SelectFeature(){
> 	    selectionXml = reqHandler.responseText;
>             sel=TrimString(selectionXml);
>            //-- first mode-----------
>              var map = GetParent().Fusion.getMapByName(mapName);
>              map.setSelection(sel, true, true);
>            //-- second mode----------
>             GetParent().SetSelectionXML(sel);
>            //-- third mode----------
>             mapWidget.setSelection(sel, z);
>            alert(mapWidget.hasSelection());
> function SetSelectionXML(selectionXml) {
>     var mapWidget = Fusion.getWidgetById('Map');
>     if (mapWidget && mapWidget.isMapLoaded()) {
>         mapWidget.setSelection(selectionXml, true, true);
>   function GetParent()
>     if(popup) {
>         return opener;
>     } else {
>         return parent.parent;
>  function TrimString(responseString)
>             responseString = responseString.replace( /^\s+/g, "" );
>             return responseString.replace( /\s+$/g, "" );
