[mapguide-users] trouble connecting mapguide maestro postgis
Remco Houtkamp
r.houtkamp at burohoutkamp.nl
Thu Sep 17 05:31:36 EDT 2009
Been strugling along. Depend.exe told libpq.dll could not be opened. I googled for it, followed instructions and installed it. Now when I press test connections, it will not give me errors...seems like progress!
I saved the data connection and tried to connect a layer. Maestro tells me:
Failed to read schema from data source.
The operation gave the error message: De externe server heeft een fout geretourneerd (Dutch for the external server returned an error): (559) MgConnectionFailedException.: Cannot establish connection.
Depend.exe also says it cannot open ieshims.dll so I just copied it (is that ok) to the FDO folder.
Now it only says Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
It also shows a hourglass and some kind of red grid on an icon for the file ieframe.dll
-----Oorspronkelijk bericht-----
Van: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Namens Zac Spitzer
Verzonden: woensdag 16 september 2009 16:08
Aan: MapGuide Users Mail List
Onderwerp: Re: [mapguide-users] trouble connecting mapguide maestro postgis
try running depends.exe (google it) on the postgis fdo provider dll
sounds like the required postgres dll's are being found
z
On Thu, Sep 17, 2009 at 12:04 AM, Remco Houtkamp
<r.houtkamp at burohoutkamp.nl> wrote:
> Hi all, this is my first post, still a newbie.
> I think I managed to import data from openstreetmap.org to postgis. But now
> I cannot connect. I guess things are working since I can connect from a
> program called Udig.
> In mapguide maestro I go through the following steps:
> Create a new resource>data connection
> OSGEO FDO Provider for Postgis
> Database: osm (is visible in Udig)
> server: I tried localhost http://localhost/ 127.0.0.1 http:// 127.0.0.1/
> Port: 5432
> Tried all three credentials but think it must be Specified Credentials with
> user postgres and my secret password ;)
> Press test connection and then the following error appears:
> De externe server heeft een fout geretourneerd: (559) MgFdoException.: An
> exception occurred in FDO component. Unable to load the FDO Provider: Kan
> opgegeven module niet vinden. (some of this is Dutch...)
> My setup contains postgresql 8.4 and postgis 1.4.
> Can anybody tell me where I'm going wrong... struggling for days and days... and
> days...
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
