[mapguide-users] trouble connecting mapguide maestro postgis
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Sep 17 08:22:28 EDT 2009
ieshims.dll and ieframe.dll can be ignored.
There should be no harm in copying the files, but it's not required.
Now that you get that error, it is likely that the error.log contains
extra information:
2.0.2: C:\Program Files\MapGuideOpenSource\Server\Logs\Error.log
2.1: C:\Program Files\OSGeo\MapGuide\Server\Logs\Error.log
The MgConnectionFailedException usually means that the MapGuide service
has stopped.
Regards,. Kenneth Skovhede, GEOGRAF A/S
Remco Houtkamp skrev:
> Been strugling along. Depend.exe told libpq.dll could not be opened. I googled for it, followed instructions and installed it. Now when I press test connections, it will not give me errors...seems like progress!
> I saved the data connection and tried to connect a layer. Maestro tells me:
> Failed to read schema from data source.
> The operation gave the error message: De externe server heeft een fout geretourneerd (Dutch for the external server returned an error): (559) MgConnectionFailedException.: Cannot establish connection.
> Depend.exe also says it cannot open ieshims.dll so I just copied it (is that ok) to the FDO folder.
> Now it only says Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
> It also shows a hourglass and some kind of red grid on an icon for the file ieframe.dll
> -----Oorspronkelijk bericht-----
> Van: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Namens Zac Spitzer
> Verzonden: woensdag 16 september 2009 16:08
> Aan: MapGuide Users Mail List
> Onderwerp: Re: [mapguide-users] trouble connecting mapguide maestro postgis
> try running depends.exe (google it) on the  postgis fdo provider dll
> sounds like the required postgres dll's are being found
> z
> On Thu, Sep 17, 2009 at 12:04 AM, Remco Houtkamp
> <r.houtkamp at burohoutkamp.nl> wrote:
>> Hi all, this is my first post, still a newbie.
>> I think I managed to import data from openstreetmap.org to postgis. But now
>> I cannot connect. I guess things are working since I can connect from a
>> program called Udig.
>> In mapguide maestro I go through the following steps:
>> Create a new resource>data connection
>> OSGEO FDO Provider for Postgis
>> Database: osm  (is visible in Udig)
>> server: I tried localhost http://localhost/ 127.0.0.1 http:// 127.0.0.1/
>> Port: 5432
>> Tried all three credentials but think it must be Specified Credentials with
>> user postgres and my secret password ;)
>> Press test connection and then the following error appears:
>> De externe server heeft een fout geretourneerd: (559) MgFdoException.: An
>> exception occurred in FDO component. Unable to load the FDO Provider: Kan
>> opgegeven module niet vinden. (some of this is Dutch...)
>> My setup contains postgresql 8.4 and postgis 1.4.
>> Can anybody tell me where I'm going wrong... struggling for days and days... and
>> days...
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090917/afe93648/attachment.html
