[mapguide-users] trouble connecting mapguide maestro postgis
Remco Houtkamp
r.houtkamp at burohoutkamp.nl
Tue Sep 22 02:25:56 EDT 2009
Jason, did not know of such list. I subscribed and off course will share
when something comes out. I 'm pretty sure it is a Mapguide FDO problem.
After I've update Quantum Gis to v 1.3 (not included within the ever so
useful osgeo4w) I'm able to connect to postgis from Quantum Gis as well
besides Udig.
If somebody here knows a solution please let me know. Do others
experience the same trouble?
Met vriendelijke groet,
Remco Houtkamp
BURO HOUTKAMP
|T: 06 14 390 205 |E: r.houtkamp at burohoutkamp.nl |P: Kweldergras 21,
1441 WP, Purmerend |
Van: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Namens Jason Birch
Verzonden: maandag 21 september 2009 22:29
Aan: MapGuide Users Mail List
Onderwerp: Re: [mapguide-users] trouble connecting mapguide maestro
postgis
I haven't played with the PostGIS provider for a long time, but it would
be key to ensure that you are using the same version of libpq (and the
other postgresql client libraries) as the provider was compiled with.
I'm not entirely sure what version that is, but someone on the fdo-users
mailing list should be able to help.
Jason
2009/9/21 Remco Houtkamp <r.houtkamp at burohoutkamp.nl>
Been away for the weekend, so I couldn't continue. This morning I made a
newe setup.
Winxp
Mapguide 2.1
Mapguide Maestro
Postgresql 8.4
Postgis 1.4
Same trouble as before with missing libpq.ddl, so I copied this file
from the postgresql tot the mapguide FDO folde. Depend.exe showed me
that there were some other files missing in the FDO folder so I copied
them as wel. After this maestro returen no errors after adding a new
connection>postgis>test connection. So I'm as far as I got before.
When I add a layer and try to connect it, I get an error. The error log
shows me:
<2009-09-21T05:20:54> 2200 127.0.0.1 Administrator
Error: Cannot establish connection.
StackTrace:
- MgFeatureServiceHandler.ProcessOperation line 83 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHan
dler.cpp
- MgOpDescribeSchemaAsXml.Execute line 110 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpDescribeSchemaA
sXml.cpp
- MgServerFeatureService.DescribeSchemaAsXml line 333 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\ServerFeatureServ
ice.cpp
- MgServerDescribeSchema.DescribeSchemaAsXml line 628 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\ServerDescribeSch
ema.cpp
- MgServerDescribeSchema.DescribeSchema line 564 file
ema.cpp
- MgServerDescribeSchema.DescribeFdoSchema line 196 file
ema.cpp
Looking forward to reponds.
-----Oorspronkelijk bericht-----
[mailto:mapguide-users-bounces at lists.osgeo.org] Namens Zac Spitzer
Verzonden: vrijdag 18 september 2009 11:11
postgis
maybe adding the bin dir for your postgres client to your path,
rather than adding just the dll to fdo?
z
On Fri, Sep 18, 2009 at 7:01 PM, Remco Houtkamp
<r.houtkamp at burohoutkamp.nl> wrote:
> Message is the same as yesterday when things did work. The lbpq.ddl is
still marked when running depend.exe. ieframe.ddl is also marked and has
a hourglass at the beginning of the line.
> The meesage is as follows:
> Error: At least one module has an unresolved import due to a missing
export function in an implicitly dependent module.
> Warning: At least one module has an unresolved import due to a missing
export function in a delay-load dependent module.
> Met vriendelijk groet,
> Remco Houtkamp
> BURO HOUTKAMP
> Verzonden: vrijdag 18 september 2009 10:56
postgis
> try depends on libpq.dll
> On Fri, Sep 18, 2009 at 6:46 PM, Remco Houtkamp
>> You guys respond faster than I can check it! Great list!
>> But... for some reason Test connection does not work anymore only
difference
>> is a restart of my laptop.
>> Logfile tells me:
>> <2009-09-18T10:40:23> 3508
>> Error: An exception occurred in FDO component.
>> Unable to load the FDO Provider: (null)
>> StackTrace:
dler.cpp
>> - MgOpTestFeatureSourceConnection.Execute line 100 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpTestFeatureSour
ceConnection.cpp
>> - MgFdoConnectionManager.Open line 262 file
c:\osgeo\mapguide_21\mgdev\server\src\common\manager\FdoConnectionManage
r.cpp
>> Maestro gives the following error:
>> De externe server heeft een fout geretourneerd: (559)
MgFdoException.:
>> Since installing/registering libpq.dll worked yesterday, I've redone
that
>> step... but no cigar... I'm trying to learn GIS for some months now,
but the
>> assumingly last obstacles are very hard to pass....
>> Remco Houtkamp
>> BURO HOUTKAMP
1441
>> WP, Purmerend |
>> [mailto:mapguide-users-bounces at lists.osgeo.org] Namens Kenneth
Skovhede,
>> GEOGRAF A/S
>> Verzonden: donderdag 17 september 2009 14:22
postgis
>> ieshims.dll and ieframe.dll can be ignored.
>> There should be no harm in copying the files, but it's not required.
>> Now that you get that error, it is likely that the error.log contains
extra
>> information:
>> 2.0.2: C:\Program Files\MapGuideOpenSource\Server\Logs\Error.log
>> 2.1: C:\Program Files\OSGeo\MapGuide\Server\Logs\Error.log
>> The MgConnectionFailedException usually means that the MapGuide
service has
>> stopped.
>> Regards,. Kenneth Skovhede, GEOGRAF A/S
>> Remco Houtkamp skrev:
>> Been strugling along. Depend.exe told libpq.dll could not be opened.
I
>> googled for it, followed instructions and installed it. Now when I
press
>> test connections, it will not give me errors...seems like progress!
>> I saved the data connection and tried to connect a layer. Maestro
tells me:
>> Failed to read schema from data source.
>> The operation gave the error message: De externe server heeft een
fout
>> geretourneerd (Dutch for the external server returned an error):
(559)
>> MgConnectionFailedException.: Cannot establish connection.
>> Depend.exe also says it cannot open ieshims.dll so I just copied it
(is that
>> ok) to the FDO folder.
>> Now it only says Warning: At least one module has an unresolved
import due
>> to a missing export function in a delay-load dependent module.
>> It also shows a hourglass and some kind of red grid on an icon for
the file
>> ieframe.dll
>> Verzonden: woensdag 16 september 2009 16:08
postgis
>> try running depends.exe (google it) on the postgis fdo provider dll
>> sounds like the required postgres dll's are being found
>> z
>> On Thu, Sep 17, 2009 at 12:04 AM, Remco Houtkamp
>> Hi all, this is my first post, still a newbie.
>> I think I managed to import data from openstreetmap.org to postgis.
But now
>> I cannot connect. I guess things are working since I can connect from
a
>> program called Udig.
>> In mapguide maestro I go through the following steps:
>> Create a new resource>data connection
>> OSGEO FDO Provider for Postgis
>> Database: osm (is visible in Udig)
>> server: I tried localhost http://localhost/ 127.0.0.1 http://
127.0.0.1/
>> Port: 5432
>> Tried all three credentials but think it must be Specified
Credentials with
>> user postgres and my secret password ;)
>> Press test connection and then the following error appears:
MgFdoException.: An
>> exception occurred in FDO component. Unable to load the FDO Provider:
Kan
>> opgegeven module niet vinden. (some of this is Dutch...)
>> My setup contains postgresql 8.4 and postgis 1.4.
>> Can anybody tell me where I'm going wrong... struggling for days and
days...
>> and
>> days...
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090922/dca47c74/attachment.html
