[mapguide-users] trouble connecting mapguide maestro postgis
Jason Birch
jason at jasonbirch.com
Mon Sep 21 16:29:20 EDT 2009
I haven't played with the PostGIS provider for a long time, but it would be
key to ensure that you are using the same version of libpq (and the other
postgresql client libraries) as the provider was compiled with. I'm not
entirely sure what version that is, but someone on the fdo-users mailing
list should be able to help.
Jason
2009/9/21 Remco Houtkamp <r.houtkamp at burohoutkamp.nl>
> Been away for the weekend, so I couldn't continue. This morning I made a
> newe setup.
> Winxp
> Mapguide 2.1
> Mapguide Maestro
> Postgresql 8.4
> Postgis 1.4
> Same trouble as before with missing libpq.ddl, so I copied this file from
> the postgresql tot the mapguide FDO folde. Depend.exe showed me that there
> were some other files missing in the FDO folder so I copied them as wel.
> After this maestro returen no errors after adding a new
> connection>postgis>test connection. So I'm as far as I got before.
> When I add a layer and try to connect it, I get an error. The error log
> shows me:
> <2009-09-21T05:20:54> 2200 127.0.0.1 Administrator
> Error: Cannot establish connection.
> StackTrace:
> - MgFeatureServiceHandler.ProcessOperation line 83 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
> - MgOpDescribeSchemaAsXml.Execute line 110 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpDescribeSchemaAsXml.cpp
> - MgServerFeatureService.DescribeSchemaAsXml line 333 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\ServerFeatureService.cpp
> - MgServerDescribeSchema.DescribeSchemaAsXml line 628 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
> - MgServerDescribeSchema.DescribeSchema line 564 file
> - MgServerDescribeSchema.DescribeFdoSchema line 196 file
> Looking forward to reponds.
> -----Oorspronkelijk bericht-----
> Van: mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] Namens Zac Spitzer
> Verzonden: vrijdag 18 september 2009 11:11
> Aan: MapGuide Users Mail List
> Onderwerp: Re: [mapguide-users] trouble connecting mapguide maestro postgis
> maybe adding the bin dir for your postgres client to your path,
> rather than adding just the dll to fdo?
> z
> On Fri, Sep 18, 2009 at 7:01 PM, Remco Houtkamp
> <r.houtkamp at burohoutkamp.nl> wrote:
> > Message is the same as yesterday when things did work. The lbpq.ddl is
> still marked when running depend.exe. ieframe.ddl is also marked and has a
> hourglass at the beginning of the line.
> > The meesage is as follows:
> > Error: At least one module has an unresolved import due to a missing
> export function in an implicitly dependent module.
> > Warning: At least one module has an unresolved import due to a missing
> export function in a delay-load dependent module.
> > Met vriendelijk groet,
> > Remco Houtkamp
> > BURO HOUTKAMP
> > |T: 06 14 390 205 |E: r.houtkamp at burohoutkamp.nl |P: Kweldergras 21,
> 1441 WP, Purmerend |
> > Verzonden: vrijdag 18 september 2009 10:56
> postgis
> > try depends on libpq.dll
> > On Fri, Sep 18, 2009 at 6:46 PM, Remco Houtkamp
> >> You guys respond faster than I can check it! Great list!
> >> But... for some reason Test connection does not work anymore only
> difference
> >> is a restart of my laptop.
> >> Logfile tells me:
> >> <2009-09-18T10:40:23> 3508
> >> Error: An exception occurred in FDO component.
> >> Unable to load the FDO Provider: (null)
> >> StackTrace:
> >> - MgOpTestFeatureSourceConnection.Execute line 100 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
> >> - MgFdoConnectionManager.Open line 262 file
> c:\osgeo\mapguide_21\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> >> Maestro gives the following error:
> >> De externe server heeft een fout geretourneerd: (559) MgFdoException.:
> >> Since installing/registering libpq.dll worked yesterday, I've redone
> that
> >> step... but no cigar... I'm trying to learn GIS for some months now, but
> the
> >> assumingly last obstacles are very hard to pass....
> >> Remco Houtkamp
> >> BURO HOUTKAMP
> 1441
> >> WP, Purmerend |
> >> [mailto:mapguide-users-bounces at lists.osgeo.org] Namens Kenneth
> Skovhede,
> >> GEOGRAF A/S
> >> Verzonden: donderdag 17 september 2009 14:22
> postgis
> >> ieshims.dll and ieframe.dll can be ignored.
> >> There should be no harm in copying the files, but it's not required.
> >> Now that you get that error, it is likely that the error.log contains
> extra
> >> information:
> >> 2.0.2: C:\Program Files\MapGuideOpenSource\Server\Logs\Error.log
> >> 2.1: C:\Program Files\OSGeo\MapGuide\Server\Logs\Error.log
> >> The MgConnectionFailedException usually means that the MapGuide service
> has
> >> stopped.
> >> Regards,. Kenneth Skovhede, GEOGRAF A/S
> >> Remco Houtkamp skrev:
> >> Been strugling along. Depend.exe told libpq.dll could not be opened. I
> >> googled for it, followed instructions and installed it. Now when I press
> >> test connections, it will not give me errors...seems like progress!
> >> I saved the data connection and tried to connect a layer. Maestro tells
> me:
> >> Failed to read schema from data source.
> >> The operation gave the error message: De externe server heeft een fout
> >> geretourneerd (Dutch for the external server returned an error): (559)
> >> MgConnectionFailedException.: Cannot establish connection.
> >> Depend.exe also says it cannot open ieshims.dll so I just copied it (is
> that
> >> ok) to the FDO folder.
> >> Now it only says Warning: At least one module has an unresolved import
> due
> >> to a missing export function in a delay-load dependent module.
> >> It also shows a hourglass and some kind of red grid on an icon for the
> file
> >> ieframe.dll
> >> [mailto:mapguide-users-bounces at lists.osgeo.org] Namens Zac Spitzer
> >> Verzonden: woensdag 16 september 2009 16:08
> postgis
> >> try running depends.exe (google it) on the postgis fdo provider dll
> >> sounds like the required postgres dll's are being found
> >> z
> >> On Thu, Sep 17, 2009 at 12:04 AM, Remco Houtkamp
> >> Hi all, this is my first post, still a newbie.
> >> I think I managed to import data from openstreetmap.org to postgis. But
> now
> >> I cannot connect. I guess things are working since I can connect from a
> >> program called Udig.
> >> In mapguide maestro I go through the following steps:
> >> Create a new resource>data connection
> >> OSGEO FDO Provider for Postgis
> >> Database: osm (is visible in Udig)
> >> server: I tried localhost http://localhost/ 127.0.0.1 http://
> 127.0.0.1/
> >> Port: 5432
> >> Tried all three credentials but think it must be Specified Credentials
> with
> >> user postgres and my secret password ;)
> >> Press test connection and then the following error appears:
> An
> >> exception occurred in FDO component. Unable to load the FDO Provider:
> Kan
> >> opgegeven module niet vinden. (some of this is Dutch...)
> >> My setup contains postgresql 8.4 and postgis 1.4.
> >> Can anybody tell me where I'm going wrong... struggling for days and
> days...
> >> and
> >> days...
> >> _______________________________________________
> >> mapguide-users mailing list
> >> mapguide-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > Zac Spitzer -
> > http://zacster.blogspot.com
> > +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090921/b741ddc3/attachment.html
