[mapguide-users] Tile base cache (how to tile the map)
Denny S
denny_sutanto1 at yahoo.com
Wed Sep 23 10:08:11 EDT 2009
Sorry i gave wrong link
here is the link i followed
http://www.jasonbirch.com/nodes/tag/mgcooker/
Denny S wrote:
> My folder is empty
> C:\Program
> Files\Autodesk\MapGuideEnterprise2009\Server\Repositories\TileCache\Samples_Sheboygan_MapsTiled_Sheboygan\S3\Base
> Layer Group\R0\C0
> I think it's because i don't have base layer group, is it ?
> Based on this link by jason birch
> http://www.jasonbirch.com/nodes/category/mapguide/
> I can see "Base Layer Group" folder under [...] Finite display scales, but
> i cannot see one in my PC.
> And also under Setup a tile build, i cannot see "Base Layer Group".
> What should i do ? what is base layer group is ?
> Thanks
> zspitzer wrote:
>> under the mapguide server directory\repositories\tilecache
>> z
>> On Wed, Sep 23, 2009 at 10:52 PM, Denny S <denny_sutanto1 at yahoo.com>
>> wrote:
>>> Thanks zspitzer,
>>> Now i can test the mgcooker.
>>> I use Sheboygan Map, then i click "Base layer groups" tab, then i
>>> clicked
>>> the MGCooker icon,
>>> I specified the user and password, then clicked "build tiles now". It
>>> ran
>>> very fast, seems like nothing happed. I cannot find the tiles that just
>>> being built. Where is it ?
>>> THanks
>>> zspitzer wrote:
>>>> scroll down, try the preview release
>>>> http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4208.msi
>>>> you can run cooker
>>>> On Wed, Sep 23, 2009 at 10:32 PM, Denny S <denny_sutanto1 at yahoo.com>
>>>> wrote:
>>>>> Wow very fast reply
>>>>> I use Version 1.0.9.15910
>>>>> I downloaded it from the link you passed me
>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
>>>>> Inside that page i click Installer (recommended) under windows current
>>>>> release
>>>>> Here is the url that i downloaded
>>>>> http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%201.0.9.msi
>>>>> Which preview should i use ?
>>>>> Thanks
>>>>> zspitzer wrote:
>>>>>> are you running 1.0.9 or the preview version?
>>>>>> i think you need the preview version?
>>>>>> On Wed, Sep 23, 2009 at 9:44 PM, Denny S <denny_sutanto1 at yahoo.com>
>>>>>> wrote:
>>>>>>> Hi zspitzer,
>>>>>>> I'm very new to mapguide, i have downloaded the mapguide maestro,
>>>>>>> then
>>>>>>> when
>>>>>>> i started the maestro, it asked me to login to my local server,i
>>>>>>> successfully connected.
>>>>>>> I have "Sheboygan Public" folder, this folder i created base on the
>>>>>>> step
>>>>>>> by
>>>>>>> step exercise provided by Map Guide Studio 2009.
>>>>>>> I browse to my Maps folder under Sheboygan Public, i clicked the map
>>>>>>> there,
>>>>>>> but i cannot see the MGCooker icon there. I have only 2 tabs inside
>>>>>>> layers
>>>>>>> section, which are "Layers by group" , "Layers by drawing order".
>>>>>>> Maybe
>>>>>>> my
>>>>>>> map is not a base layer group ?
>>>>>>> How do i create one ? What should i do to test the mgcooker. I want
>>>>>>> to
>>>>>>> create map tile same as google map. For example : 0_0.gif, 0_1.gif,
>>>>>>> 1_0.gif,
>>>>>>> etc
>>>>>>> Thanks
>>>>>>> zspitzer wrote:
>>>>>>>> the tile cache is created on demand simply by viewing a tiled map
>>>>>>>> a tiled map is a map which has base layer groups
>>>>>>>> changing anything connected to the map, ie layers, will flush the
>>>>>>>> tile
>>>>>>>> cache
>>>>>>>> On Fri, Jun 19, 2009 at 10:49 AM, CroNicoRn<ah_jid at yahoo.com>
>>>>>>>> wrote:
>>>>>>>>> d screen shot where d tiles make..
>>>>>>>>> http://n2.nabble.com/file/n3116839/mapguide_tiles.jpg
>>>>>>>>> http://www.myguidepages.com
>>>>>>>>> http://n2.nabble.com/file/u115131/ajid.jpg
>>>>>>>>> View this message in context:
>>>>>>>>> http://n2.nabble.com/Tile-base-cache-%28how-to-tile-the-map%29-tp3066013p3116839.html
>>>>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>>>>> _______________________________________________
>>>>>>>>> mapguide-users mailing list
>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>>>> Zac Spitzer -
>>>>>>>> http://zacster.blogspot.com
>>>>>>>> +61 405 847 168
>>>>>>> http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699041.html
>>>>>> Zac Spitzer -
>>>>>> +61 405 847 168
>>>>> http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699254.html
>>>> Zac Spitzer -
>>>> +61 405 847 168
>>> http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699395.html
>> Zac Spitzer -
>> +61 405 847 168
View this message in context: http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699848.html
