[mapguide-users] Tile base cache (how to tile the map)
    Kenneth Skovhede, GEOGRAF A/S
    ks at geograf.dk
    Thu Sep 24 01:45:29 EDT 2009
A group in MapGuide is a collection of layers, and so is a base layer group.
When MapGuide produces tiles, produces a set of tiles for each base
layer group.
Typical usage would be to have a technical map of the area, an arial,
and a hybrid map.
Each setup would be in its own base layer group, so you can switch the
underlying map,
but still display dynamic data on top, eg. vehicle positions.
You do this seperation as once the tile is created, any changes to data
will not show (as it is an image now).
If you have data that you update, or want to turn layers on/off they
should not be in a base layer group.
MapGuide enables you to have dynamic and static data in the same map.
Regards, Kenneth Skovhede, GEOGRAF A/S
Denny S skrev:
> My folder is empty
> C:\Program
> Files\Autodesk\MapGuideEnterprise2009\Server\Repositories\TileCache\Samples_Sheboygan_MapsTiled_Sheboygan\S3\Base
> Layer Group\R0\C0
> I think it's because i don't have base layer group, is it ?
> Based on this link by jason birch
> http://www.jasonbirch.com/nodes/category/mapguide/
> I can see "Base Layer Group" folder under [...] Finite display scales, but i
> cannot see one in my PC.
> And also under Setup a tile build, i cannot see "Base Layer Group".
> What should i do ? what is base layer group is ?
> Thanks
> zspitzer wrote:
>> under the mapguide server directory\repositories\tilecache
>> z
>> On Wed, Sep 23, 2009 at 10:52 PM, Denny S <denny_sutanto1 at yahoo.com>
>> wrote:
>>> Thanks zspitzer,
>>> Now i can test the mgcooker.
>>> I use Sheboygan Map, then i click "Base layer groups" tab, then i clicked
>>> the MGCooker icon,
>>> I specified the user and password, then clicked "build tiles now". It ran
>>> very fast, seems like nothing happed. I cannot find the tiles that just
>>> being built. Where is it ?
>>> THanks
>>> zspitzer wrote:
>>>> scroll down, try the preview release
>>>> http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4208.msi
>>>> you can run cooker
>>>> On Wed, Sep 23, 2009 at 10:32 PM, Denny S <denny_sutanto1 at yahoo.com>
>>>> wrote:
>>>>> Wow very fast reply
>>>>> I use Version 1.0.9.15910
>>>>> I downloaded it from the link you passed me
>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
>>>>> Inside that page i click Installer (recommended) under windows current
>>>>> release
>>>>> Here is the url that i downloaded
>>>>> http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%201.0.9.msi
>>>>> Which preview should i use ?
>>>>> Thanks
>>>>> zspitzer wrote:
>>>>>> are you running 1.0.9 or the preview version?
>>>>>> i think you need the preview version?
>>>>>> On Wed, Sep 23, 2009 at 9:44 PM, Denny S <denny_sutanto1 at yahoo.com>
>>>>>> wrote:
>>>>>>> Hi zspitzer,
>>>>>>> I'm very new to mapguide, i have downloaded the mapguide maestro,
>>>>>>> then
>>>>>>> when
>>>>>>> i started the maestro, it asked me to login to my local server,i
>>>>>>> successfully connected.
>>>>>>> I have "Sheboygan Public" folder, this folder i created base on the
>>>>>>> step
>>>>>>> by
>>>>>>> step exercise provided by Map Guide Studio 2009.
>>>>>>> I browse to my Maps folder under Sheboygan Public, i clicked the map
>>>>>>> there,
>>>>>>> but i cannot see the MGCooker icon there. I have only 2 tabs inside
>>>>>>> layers
>>>>>>> section, which are "Layers by group" , "Layers by drawing order".
>>>>>>> Maybe
>>>>>>> my
>>>>>>> map is not a base layer group ?
>>>>>>> How do i create one ? What should i do to test the mgcooker. I want
>>>>>>> to
>>>>>>> create map tile same as google map. For example : 0_0.gif, 0_1.gif,
>>>>>>> 1_0.gif,
>>>>>>> etc
>>>>>>> Thanks
>>>>>>> zspitzer wrote:
>>>>>>>> the tile cache is created on demand simply by viewing a tiled map
>>>>>>>> a tiled map is a map which has base layer groups
>>>>>>>> changing anything connected to the map, ie layers, will flush the
>>>>>>>> tile
>>>>>>>> cache
>>>>>>>> On Fri, Jun 19, 2009 at 10:49 AM, CroNicoRn<ah_jid at yahoo.com> wrote:
>>>>>>>>> d screen shot where d tiles make..
>>>>>>>>> http://n2.nabble.com/file/n3116839/mapguide_tiles.jpg
>>>>>>>>> http://www.myguidepages.com
>>>>>>>>>  http://n2.nabble.com/file/u115131/ajid.jpg
>>>>>>>>> View this message in context:
>>>>>>>>> http://n2.nabble.com/Tile-base-cache-%28how-to-tile-the-map%29-tp3066013p3116839.html
>>>>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>>>>> _______________________________________________
>>>>>>>>> mapguide-users mailing list
>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>>>> Zac Spitzer -
>>>>>>>> http://zacster.blogspot.com
>>>>>>>> +61 405 847 168
>>>>>>> http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699041.html
>>>>>> Zac Spitzer -
>>>>>> +61 405 847 168
>>>>> http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699254.html
>>>> Zac Spitzer -
>>>> +61 405 847 168
>>> http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699395.html
>> Zac Spitzer -
>> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090924/ff2dc381/attachment.html
