[mapguide-users] Tile base cache (how to tile the map)
Denny S denny_sutanto1 at yahoo.com
Fri Sep 25 06:39:12 EDT 2009
Hi Kenneth,
Thanks for your explanation,
I finally can make it work now, i can create "base layer group" using
mapguide studio.
Thanks all
Kenneth Skovhede, GEOGRAF A/S wrote:
> A group in MapGuide is a collection of layers, and so is a base layer
> group.
> When MapGuide produces tiles, produces a set of tiles for each base
> layer group.
> Typical usage would be to have a technical map of the area, an arial,
> and a hybrid map.
> Each setup would be in its own base layer group, so you can switch the
> underlying map,
> but still display dynamic data on top, eg. vehicle positions.
> You do this seperation as once the tile is created, any changes to data
> will not show (as it is an image now).
> If you have data that you update, or want to turn layers on/off they
> should not be in a base layer group.
> MapGuide enables you to have dynamic and static data in the same map.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Denny S skrev:
>> My folder is empty
>> C:\Program
>> Files\Autodesk\MapGuideEnterprise2009\Server\Repositories\TileCache\Samples_Sheboygan_MapsTiled_Sheboygan\S3\Base
>> Layer Group\R0\C0
>> I think it's because i don't have base layer group, is it ?
>> Based on this link by jason birch
>> http://www.jasonbirch.com/nodes/category/mapguide/
>> I can see "Base Layer Group" folder under [...] Finite display scales,
>> but i
>> cannot see one in my PC.
>> And also under Setup a tile build, i cannot see "Base Layer Group".
>> What should i do ? what is base layer group is ?
>> Thanks
>> zspitzer wrote:
>>> under the mapguide server directory\repositories\tilecache
>>> z
>>> On Wed, Sep 23, 2009 at 10:52 PM, Denny S <denny_sutanto1 at yahoo.com>
>>> wrote:
>>>> Thanks zspitzer,
>>>> Now i can test the mgcooker.
>>>> I use Sheboygan Map, then i click "Base layer groups" tab, then i
>>>> clicked
>>>> the MGCooker icon,
>>>> I specified the user and password, then clicked "build tiles now". It
>>>> ran
>>>> very fast, seems like nothing happed. I cannot find the tiles that just
>>>> being built. Where is it ?
>>>> THanks
>>>> zspitzer wrote:
>>>>> scroll down, try the preview release
>>>>> http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4208.msi
>>>>> you can run cooker
>>>>> On Wed, Sep 23, 2009 at 10:32 PM, Denny S <denny_sutanto1 at yahoo.com>
>>>>> wrote:
>>>>>> Wow very fast reply
>>>>>> I use Version 1.0.9.15910
>>>>>> I downloaded it from the link you passed me
>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
>>>>>> Inside that page i click Installer (recommended) under windows
>>>>>> current
>>>>>> release
>>>>>> Here is the url that i downloaded
>>>>>> http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%201.0.9.msi
>>>>>> Which preview should i use ?
>>>>>> Thanks
>>>>>> zspitzer wrote:
>>>>>>> are you running 1.0.9 or the preview version?
>>>>>>> i think you need the preview version?
>>>>>>> On Wed, Sep 23, 2009 at 9:44 PM, Denny S <denny_sutanto1 at yahoo.com>
>>>>>>> wrote:
>>>>>>>> Hi zspitzer,
>>>>>>>> I'm very new to mapguide, i have downloaded the mapguide maestro,
>>>>>>>> then
>>>>>>>> when
>>>>>>>> i started the maestro, it asked me to login to my local server,i
>>>>>>>> successfully connected.
>>>>>>>> I have "Sheboygan Public" folder, this folder i created base on the
>>>>>>>> step
>>>>>>>> by
>>>>>>>> step exercise provided by Map Guide Studio 2009.
>>>>>>>> I browse to my Maps folder under Sheboygan Public, i clicked the
>>>>>>>> map
>>>>>>>> there,
>>>>>>>> but i cannot see the MGCooker icon there. I have only 2 tabs inside
>>>>>>>> layers
>>>>>>>> section, which are "Layers by group" , "Layers by drawing order".
>>>>>>>> Maybe
>>>>>>>> my
>>>>>>>> map is not a base layer group ?
>>>>>>>> How do i create one ? What should i do to test the mgcooker. I want
>>>>>>>> to
>>>>>>>> create map tile same as google map. For example : 0_0.gif, 0_1.gif,
>>>>>>>> 1_0.gif,
>>>>>>>> etc
>>>>>>>> Thanks
>>>>>>>> zspitzer wrote:
>>>>>>>>> the tile cache is created on demand simply by viewing a tiled map
>>>>>>>>> a tiled map is a map which has base layer groups
>>>>>>>>> changing anything connected to the map, ie layers, will flush the
>>>>>>>>> tile
>>>>>>>>> cache
>>>>>>>>> On Fri, Jun 19, 2009 at 10:49 AM, CroNicoRn<ah_jid at yahoo.com>
>>>>>>>>> wrote:
>>>>>>>>>> d screen shot where d tiles make..
>>>>>>>>>> http://n2.nabble.com/file/n3116839/mapguide_tiles.jpg
>>>>>>>>>> http://www.myguidepages.com
>>>>>>>>>>  http://n2.nabble.com/file/u115131/ajid.jpg
>>>>>>>>>> View this message in context:
>>>>>>>>>> http://n2.nabble.com/Tile-base-cache-%28how-to-tile-the-map%29-tp3066013p3116839.html
>>>>>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>>>>>> _______________________________________________
>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>>>>> Zac Spitzer -
>>>>>>>>> http://zacster.blogspot.com
>>>>>>>>> +61 405 847 168
>>>>>>>> http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699041.html
>>>>>>> Zac Spitzer -
>>>>>>> +61 405 847 168
>>>>>> http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699254.html
>>>>> Zac Spitzer -
>>>>> +61 405 847 168
>>>> http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3699395.html
>>> Zac Spitzer -
>>> +61 405 847 168
View this message in context: http://n2.nabble.com/Tile-base-cache-how-to-tile-the-map-tp3066013p3711596.html
