[mapguide-users] SQLITE...and Mapguide/AJAX Multiple Selection problem?
Scott hameister
scotth at mpowerinnovations.com
Wed Sep 23 17:28:17 EDT 2009
I cant control the column order since bulkcopy does what it feels like doing
with column names...normally alphabetizing them...or it may have gotten that
way because it was in MYSQL spatial originally...Not sure
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Wednesday, September 23, 2009 4:15 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] SQLITE...and Mapguide/AJAX Multiple Selection
problem?
We'll check your file.
It looks valid to me, but one thing I notice that is different is that the
geometry column is the last column in your table. There are some
optimizations in the provider which were added last week, which do different
SQL queries based on the order of the columns, and there may well be a new
bug there which I don't see with my data since it is using different order.
If it turns out to be a bug in the provider, I will post new DLLs and post
to the list when it's done.
Traian
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Scott hameister
> Sent: Wednesday, September 23, 2009 4:44 PM
Selection
> problem?
> Email has been sent with attached file to you...If it works good for you
ill
> be completely stumped
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Scott
hameister
> Sent: Wednesday, September 23, 2009 3:39 PM
Selection
> problem?
> Im not sure my files not a defect now..I'll email you a link
> Sent: Wednesday, September 23, 2009 2:59 PM
Selection
> problem?
> Yes, create a defect ticket here: http://trac.osgeo.org/fdo/ and attach a
> zip of your file to it.
> Traian
> > Sent: Wednesday, September 23, 2009 3:54 PM
> Selection
> > problem?
> > Can I have you look at my SQLite file and see if its not somehow the
file?
> > I'm at a complete loss..
> > When I make the data connection that goes smoothly..When I try to
preview
> in
> > the data connection a couple layer actually do preview..But when I
create
> a
> > layer and try a preview it goes to a scale of 10...I am thoroughly
> > exhausted...I could not get the 3.4 to work in Map 2010 at all....but
> that's
> > OK.
> > If I use the older 3.4 driver from OSGEO my layers display but I get the
> > selection problem.
Stanev
> > Sent: Wednesday, September 23, 2009 2:47 PM
> Selection
> > problem?
> > For what it's worth, I just tried the SQLiteProvider DLL I posted for
> > 3.4 on a MG 2.1 RC install (dated May 1, 2009) and was able to create a
> > SQLite based layer using Maestro and did a multi-select without
problems.
> > I have no reason to think that the 3.3 build is any different from the
3.4
> > one since I used the same version of the code to compile each one --
> > granted, for 3.3 I had to use a different version of Visual Studio, but
> that
> > should not be a problem if you have the runtimes installed.
> > Traian
> > > Sent: Wednesday, September 23, 2009 2:51 PM
> > Selection
> > > problem?
> > > Cant get it working Installed both of those and rebooted.
> > > Installed a 2.1 Beta release on a new machine and tried the 3.4 you
gave
> > me
> > > to no avail, downloaded the official 3.4 driver from OSGEO and Im back
> to
> > > having the selection issue again...
> > > ...Its hard to believe Im the first to need to select more than one
> object
> > > with this driver?????
> > > What version do you run that seems to work on selections? What
installed
> > > Mapguide and FDO level/driver?
> Stanev
> > > Sent: Wednesday, September 23, 2009 12:10 PM
> > Selection
> > > problem?
> > > Also make sure that you have installed both the regular and SP1
runtimes
> > for
> > > Visual Studio 2005:
http://www.microsoft.com/downloads/details.aspx?familyid=32BC1BEE-A3F9-4C13-
> > > 9C99-220B62A191EE&displaylang=en
http://www.microsoft.com/downloads/details.aspx?FamilyID=200B2FD9-AE1A-4A14-
> > > 984D-389C36F85647&displaylang=en
> > > It could be that your FDO was compiled with SP1 and the provider is
> > compiled
> > > without SP1 of the Visual C++ runtime.
> > > Traian
> > > > Sent: Wednesday, September 23, 2009 12:55 PM
> > > Selection
> > > > problem?
> > > > Do you have the DLL dependency tool to check if the provider DLL is
> not
> > > > missing any DLL dependency?
> > > > Do you have MapStudio by any chance? You can try to see if you get
the
> > > same
> > > > problem there.
> > > > There should be only one connection property, called "File", are you
> > > saying
> > > > that you cannot see it?
> > > > > Sent: Wednesday, September 23, 2009 12:45 PM
> > > > Selection
> > > > > problem?
> > > > > Im getting an oddball error when trying to make a data connection
in
> > > > studio
> > > > > 2009...
> > > > > The Connection Properties for Property, translated Name, Value are
> > > showing
> > > > > up but have no where to edit them..So I cant do anything
Traian
> > > Stanev
> > > > > Sent: Wednesday, September 23, 2009 11:03 AM
> > > > Selection
> > > > > problem?
> > > > > I posted builds of the latest SQLite provider code compiled
against
> > FDO
> > > > 3.3
> > > > > and also 3.4 at:
> > > > > http://13-9.com/SQLiteProvider-3.3.zip
> > > > > and
> > > > > http://13-9.com/SQLiteProvider-3.4.zip
> > > > > respectively. Due to differences in the FDO API, I had to hack
> around
> > a
> > > > bit
> > > > > of stuff, and I only gave the provider very rudimentary testing (I
> > > opened
> > > > a
> > > > > sqlite file and read some data from it).
> > > > > Let me know if there are still problems with selection, even with
> this
> > > new
> > > > > DLL. If there are, then I suggest you file a bug report against
the
> > > > provider
> > > > > and attach some sample data to it so we can debug it.
> > > > > Traian
> > > > > > Sent: Tuesday, September 22, 2009 9:18 PM
Multiple
> > > > > Selection
> > > > > > problem?
> > > > > > THANKS
> Traian
> > > > Stanev
> > > > > > Sent: Tuesday, September 22, 2009 8:07 PM
Multiple
> > > > > Selection
> > > > > > problem?
> > > > > > Yeah it will not work. I'll attempt to compile it with 3.3 and
> post
> > > > again
> > > > > to
> > > > > > the list whenever it's done.
> > > > > > Traian
> > > > > > > Sent: Tuesday, September 22, 2009 8:58 PM
> Multiple
> > > > > > > Selection problem?
> > > > > > > Id be willing to move up to FDO 3.4 But I thought Studio 2009
> and
> > > > > > > Mapguide
> > > > > > > Open Source 2.0.2 Were Permanantly forced to use 3.3...Can I
run
> > 3.4
> > > > on
> > > > > > > these?
> > Traian
> > > > > > > Stanev
> > > > > > > Sent: Tuesday, September 22, 2009 7:41 PM
> > > > > > > To: MapGuide Users Mail List
> Multiple
> > > > > > > Selection
> > > > > > > problem?
> > > > > > > Well, considering this is FDO 3.3, which is seriously old,
there
> > > > > > > probably
> > > > > > > isn't a build of the latest SQLite provider against FDO 3.3.
It
> > > would
> > > > > > > have
> > > > > > > to be a custom build of the trunk 3.5 SQLite FDO code against
> the
> > > old
> > > > > > > FDO
> > > > > > > 3.3 libraries. I'll check how hard that would be to do, I'm
> > guessing
> > > > > > > there
> > > > > > > is no chance for you to use FDO 3.4, given that you have
> deployed
> > > > > > > already?
> > > > > > > Traian
> > > > > > > ________________________________________
> > > > > > > [mapguide-users-bounces at lists.osgeo.org] On Behalf Of Scott
> > > hameister
> > > > > > > [scotth at mpowerinnovations.com]
> > > > > > > Sent: Tuesday, September 22, 2009 7:51 PM
> > > > > > > Multiple
> > > > > > > Selection problem?
> > > > > > > The Zip Was called FdoSQLiteProvider_3.3.0_r4270 11/26/2008 on
> > > > > > > SQLITEPROVIDER.dll
> > > > > > > MapGuide Server (Version 2.0.2.3011)
> > > > > > > God I hope yopu are right...Where do you get the newer files?
> > Traian
> > > > > > > Stanev
> > > > > > > Sent: Tuesday, September 22, 2009 6:39 PM
> Multiple
> > > > > > > Selection
> > > > > > > problem?
> > > > > > > What is the date of your SQLite dll (and what version of
> MapGuide,
> > > > FDO)?
> > > > > > > There have been numerous fixes done to the SQLite provider in
> the
> > > last
> > > > > > > few
> > > > > > > months, and your problem has also likely been fixed.
> > > > > > > Traian
> > > hameister
> > > > > > > Sent: Tuesday, September 22, 2009 6:23 PM
> Multiple
> > > > > > > Selection problem?
> > > > > > > I just noticed that making selections on any Layer in studio
of
> > > > > > > multiple
> > > > > > > objects has some odd results as well????
> > > > > > > Anyone know why this is? I download my FDo driver from Jason
> > birch's
> > > > > > > Website...is there a newer one out there?
> > > > > > > I finally got this customer entirely ported over to SQLite and
> now
> > > it
> > > > > > > looks
> > > > > > > unusable...
> > > > > > > PS just tried the fusion viewr in studio Selected a big square
> of
> > > > > > > objects...the Fusion viewer shows I selected 84 objects based
on
> > the
> > > > > > > selection tab, but the map visually only shows about 8 objects
> > > > selected
> > > > > > > randomly through my original box.
> > > > > > > Anyone having success with multiple selections/or facing the
> same
> > > > > > > problem.????????
> > Flipper
> > > > > > > Sent: Tuesday, September 22, 2009 5:08 PM
> > > > > > > To: mapguide-users at lists.osgeo.org
> > > > > > > Subject: [mapguide-users] SQLITE...and Mapguide/AJAX Multiple
> > > > Selection
> > > > > > > problem?
> > > > > > > I'm Trying to utilize SQLITE in Mapguide...
> > > > > > > I'm succesfully getting and creating selection filters with
the
> > > > API...I
> > > > > > > see
> > > > > > > the Appropriate XML (see below)...
> > > > > > > I sent this into the AJAX
> > > > > > > myframe.mapFrame.SetSelectionXML(selectionXml);
> > > > > > > and refreshed and it only selects one object...I noticed the
> same
> > > > > > > problem
> > > > > > > When I make a rectangular selection over several objects and
it
> > > > Reports
> > > > > > > back
> > > > > > > only one objects...Im confused as to what is happening
here....
> > > > > > > Anybody else having any issues? Mapguide 2.0 OS
> > > > > > > This is the Selection XML being sent into
> > > > > > > <?xml version="1.0" encoding="UTF-8"?><FeatureSet
> > > > > > > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> > > > > > > xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
> > > > > > > id="0e2be5e2-0000-1000-8001-000423cc7e07"> <Class
> > > id="Default:SANPIPE">
> > > > > > > <ID>EgAAAA==</ID> <ID>EwAAAA==</ID> <ID>FAAAAA==</ID>
> > > <ID>FQAAAA==</ID>
> > > > > > > <ID>FgAAAA==</ID> <ID>FwAAAA==</ID> <ID>GAAAAA==</ID>
> > > <ID>GQAAAA==</ID>
> > > > > > > <ID>GgAAAA==</ID> <ID>GwAAAA==</ID> <ID>HAAAAA==</ID>
> > > <ID>HQAAAA==</ID>
> > > > > > > <ID>HgAAAA==</ID> <ID>HwAAAA==</ID> <ID>IAAAAA==</ID>
> > > <ID>IQAAAA==</ID>
> > > > > > > <ID>IgAAAA==</ID> <ID>IwAAAA==</ID> <ID>JAAAAA==</ID>
> > > <ID>JQAAAA==</ID>
> > > > > > > <ID>JgAAAA==</ID> <ID>JwAAAA==</ID> <ID>KgAAAA==</ID>
> > > <ID>KwAAAA==</ID>
> > > > > > > <ID>LAAAAA==</ID> <ID>LQAAAA==</ID> <ID>LgAAAA==</ID>
> > > <ID>LwAAAA==</ID>
> > > > > > > <ID>MAAAAA==</ID> <ID>MQAAAA==</ID> <ID>MgAAAA==</ID>
> > > <ID>MwAAAA==</ID>
> > > > > > > <ID>NAAAAA==</ID> <ID>NQAAAA==</ID> <ID>OwAAAA==</ID>
> > > <ID>PAAAAA==</ID>
> > > > > > > <ID>RQAAAA==</ID> <ID>RgAAAA==</ID> <ID>SAAAAA==</ID>
> > > <ID>SQAAAA==</ID>
> > > > > > > <ID>SgAAAA==</ID> <ID>TQAAAA==</ID> <ID>TgAAAA==</ID>
> > > <ID>TwAAAA==</ID>
> > > > > > > <ID>UAAAAA==</ID> <ID>UQAAAA==</ID> <ID>tAAAAA==</ID>
> > > <ID>tQAAAA==</ID>
> > > > > > > </Class> </Layer></FeatureSet>
> > > > > > > View this message in context:
> http://n2.nabble.com/SQLITE-and-Mapguide-AJAX-Multiple-Selection-
> > > > > > > problem-tp3
> > > > > > > 696007p3696007.html
> > > > > > > Sent from the MapGuide Users mailing list archive at
Nabble.com.
> > > > > > > _______________________________________________
> > > > > > > mapguide-users mailing list
> > > > > > > http://lists.osgeo.org/mailman/listinfo/mapguide-users
