[mapguide-users] JSP and PHP and fusion
Andreas Morf a.morf at fkl.ch
Thu Sep 24 04:36:50 EDT 2009
It's quite easy to use java/jsp as alternative/extension to php:
As I also prefer programming in java over php, so the server side logic of
my additional fusion widgets is implemented as java servlets/jsp.
Coding with eclipse and debugging of servlets with the eclipse-tomcat plugin
is just very comfortable.
This environment allowed me to implement a PDF-Plot widget with map-rotation
capabilities quite fluently.
Compared to that, development of client side javascript-fusion code is
really a pain in...
Andreas
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of oshan
> Sent: Thursday, September 24, 2009 9:33 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] JSP and PHP and fusion
> Hey Guys
> So I'm just trying to get started with mapguide. I want to know if
> there is
> any Documentation specific to using the JSP API. The developers guide
> seams
> focus on PHP.
> Also what do you guys think is better to use PHP or JSP?
> The reason why I am leaning towards JSP is because it is essentially
> Java
> programming and I am familiar with Java (altho I have never used
> JSP)where
> as I have only slight knowledge with PHP and I also have the perception
> that
> since its Java with the whole OO stuff, it'll prolly be easy to program
> in!?
> Since I couldn't find any JSP documentation I looked at the sample JSP
> ajax
> viewer code and it looks a bit scary: there is a whole lot of code! I
> would
> like to see more of a step by step approach with JSP.
> Also I looked into this fusion thing but it seams a bit buggy. I don't
> know
> if any of you have experienced that. Like I would specify some widgets
> but
> they would never show up. I heard that fusion use PHP for it server
> stuff.
> Does this mean I have to configure mapguide to use PHP instead of JSP.
> when
> I install it I set it up to use JSP!
> thanks
> View this message in context: http://n2.nabble.com/JSP-and-PHP-and-
> fusion-tp3704607p3704607.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
